Spherical Knurl
Spherical Knurl
Hi all,
I'm trying to create a knurl on the surface of a sphere based on an icosahedral groove. To do this, I created a sphere and I need to run grooves about a few different datum lines. When I go to make the second groove, my computer exudes heat for about 10 minutes then eventually FreeCAD draws some lines across the surface of the sphere (i.e. the groove doesn't actually eliminate material from the sphere). I'm a bit stuck here, any help appreciated.
When I leave the second groove in the FCStd file, the size skyrockets to 2 MB, so I can't attach it. In the attached, add a groove of Sketch XZSlots2 about DatumLine001. This should exhibit the behavior I describe above.
- KnurledSphere.FCStd
- (149.87 KiB) Downloaded 25 times
Re: Spherical Knurl
Welcome.to the forum!
Please have a look at the big red banner at the top and provide your full FreeCAD information.
Thanks!
Thanks!
Regards / Viele Grüße
Max
Max
Re: Spherical Knurl
Info isn't working for me. I can tell you that I'm on v0.19.3 for OSX.
- Screen Shot 2022-05-24 at 9.24.31 PM.png (65.59 KiB) Viewed 1116 times
Re: Spherical Knurl
I've never seen this error before. @chrisb you're on a Mac too if I recall correctly. Have you seen this error before?
Max
Max
Re: Spherical Knurl
... KISS in PartWB:
- KnurledSphere_4.FCStd
- FC.20
- (39.91 KiB) Downloaded 13 times
- KnurledSphere_3.FCStd
- FC.20
- (47.53 KiB) Downloaded 13 times
- FC.20_28886
- (28.84 KiB) Downloaded 12 times
- papyblaise
Re: Spherical Knurl
I'm modest, I do grove after grove, on a half sphere and end up with a Mirror, which I don't know how to do in PD Wb
- KnurledSphere1.FCStd
- (87.72 KiB) Downloaded 13 times
- KnurledSphere1.JPG (53.85 KiB) Viewed 978 times
Re: Spherical Knurl
No. I don't have the file mentioned in the error message. in my 0.20 installation. I recommend to clean the config files, and perhaps the whole directory.
Re: Spherical Knurl
No errors. Second groove is slow... Passes Geometry check - slow.
[/code]
[code]
OS: macOS High Sierra (10.13)
Version: 0.20.28909 (Git)
Hash: 6beef68ae1
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
* Curves 0.3.0
* DynamicData 2.45.0
* fasteners 0.3.40
* fcgear 1.0.0
* Help 1.0.0-alpha
* lattice2 1.0.0
* MeshRemodel 1.8919.0
* toSketch
Re: Spherical Knurl
Re: Spherical Knurl
... I understand, it must be FreeCAD on the BBQ screen on heavy load when "knurling".
I think the cutting task is the showstopper.
Here another trial.
Here another trial.
- KnurledSphere_5.FCStd
- FC.20 28886
- (24.39 KiB) Downloaded 15 times
