I am using Sheet Metal V0.2.31 in FreeCAD version 0.19 to create the base of an enclosure. I am seeking help on how to delete an object in a tree view and fix error with 'NoneType object is not subscriptable' error message.
I am attaching the Before, After, and png files for reference. The object that I would like to delete is shown in png file and labeled as 'Extend003 Rear' in FreeCAD Before file.
In the Before file, I deleted this Extend003 from the Tree View but this action created the above error with the object below it, shown in the After file. The rear surface is identified as Face38 and I think I have to attach Bend008 to this surface somehow to fix this broken model.
As aside question, are there any tutorials/documentation/info on how FreeCAD Sheet Metal works in terms of model revision (object moves/adds/changes)?. I have searched FreeCAD Tutorials and YouTube.
Any help would be very much appreciated. Thank you.
FreeCAD details:
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
How to delete an object in tree view and correct "NoneType" object errors
- Base_Rev200_Before.FCStd
- (193.95 KiB) Downloaded 12 times
- Base_Rev200_After.FCStd
- (178.17 KiB) Downloaded 11 times
- RearExtend.png (21.49 KiB) Viewed 529 times
- papyblaise
Re: How to delete an object in tree view and correct "NoneType" object errors
Sheetmetal like any other workshop is sensitive to topological renaming, so deleting an operation in the tree will inevitably cause a mess later
Tuto:
https://wiki.freecadweb.org/SheetMetal_Workbench/fr
Tuto:
Hello and thanks for your input.
I had a look at that link and the limitations on topological naming does not sound good. Now I can see why I had strange problems earlier in revising a design where a change to an object leads to strange result on unrelated object.
Does it mean I have to delete all objects after that Extend003 and recreate them after Delete?.
In going forward, is it possible to join bodies to create a final model?. Meaning, instead of building up a complete model in one body, I can create separate bodies (e.g., bottom, left side, right side, top side) so if there is a change in one body that has this topological naming issue, I just re-create that body only and rejoin the bodies instead of backtracking/reworking the whole thing to that changed object?. Or, do you have any recommendations in dealing with this limitation?.
I am just curious as to why permanent IDs (Edge1, Edge2, Face1, Face2, etc.) does not resolve this topological naming issue as it should, if software uses unique/one time assignment and keeps track of active IDs.
Thank you.
Thank you.
- Shalmeneser
You can reattach Bend008 Rear 45 :
* select its Data : base Object
* open the full menu : [...]
* select the right face in the object (need to zoom in to be able able to catch it)
File : other flow
File : other flow
- Capture d’écran 2022-05-24 210701.jpg (68.02 KiB) Viewed 441 times
- Base_Rev200_Before_SHALM.FCStd
- (83.65 KiB) Downloaded 10 times
