need help on groove
dr who
need help on groove
Post by dr who »
I have a part like this:
and I'd like to add some grooves to the major hole.
On my first try I selected the inclined face and created a new sketch (the white circle). But using pocket I can't get pocket to look like a groove (didn't know about groove at that time).
Then I read about groove from freecad wiki. So I created a new sketch for the groove to get rotated like this:
But I found no way to select the right rotation axis.
So I added a construction line to the sketch, but it can't be selected from outside of sketch editor.
So how can I get those grooves done?
Willem
Re: need help on groove
Post by Willem »
Make a Datum line in the center of the face you want to make a groove in
Next make a Datum plane on the Datum line.
Make a sketch on this Datum plane
Groove this sketch.
See Fcstd file for a simple example
grooves.FCStd
(33.33 KiB) Downloaded 16 times
Shalmeneser
Post by Shalmeneser »
@Willem :
you should support your DatumLine with Sketch001 and not a face (TNP).
grooves_SHALM.FCStd
(26.27 KiB) Downloaded 14 times
Willem
Post by Willem »
@Shalmeneser You are right. I think I did this wrong because of the speed and being tired at the late time of the evening. Thank you for making this correction
papyblaise
Post by papyblaise »
can you attach your file to us, there is surely a simpler grandfather's solution :lol:
dr who
Post by dr who »
Make a Datum line in the center of the face you want to make a groove in ...
Thank you very much! That was the key :)
I didn't want to have hole/boring and groove in one sketch, but with the help of Datum line I could solve, what I wanted to do.
And selecting the front circle from the boring results in a centerline Datum line as default. Very nice!
Of cause there is!
I'm the opposite of a freecad specialist, so anybody can do better.
But that's not important.
I am glad that I was helped and I am satisfied with that.
