SOLVED: Spacemouse not working (MacOSX)
osbock
Post by osbock »
I've read the older posts here, and I guess the current Mac downloads don't have the 3DConnexion spacemouse support built in.
I tried both the "stable" .19 and my preferred .20 weekly builds.
Are there any current builds that support the Space Mouse?
edit-- turns out slightly older version of the driver only partially work on Mac OSX Monterey
10.7.2 with the Beta .20 homebrew build seems to work well
Re: Spacemouse not working (MacOSX)
Post by Kunda1 »
Please always post your full About info
michust
Post by michust »
I just had the same issue, it is the 10.7.2 driver from 3dconnexion
It worked very well with the current FreeCad release (0.19 24366) and the driver 10.7.0
I asked 3Dconnexion to provide me a source for the old driver and got only a useless answer "Use supported sw, bla bla..."
Post by Kunda1 »
@ipatch have you seen issues with lack of spacemouse support in the v0.20dev homebrew builds ?
osbock
Post by osbock »
I finally got it working, the older driver I had was seemingly partially incompatible with Freecad (and some others) on Mac OSX Monterrey
My current setup:
OS: macOS 12.4
Version: 0.20.28901 +34 (Git)
Branch: ipatch.builds.0.20beta1
Hash: 8505cf72df8794d39f847939f751b2d0c15c57a5
Python 3.10.4, Qt 5.15.3, Coin 4.0.1, OCC 7.6.2
Installed mods:
  * Assembly4 0.11.12
3DxWare 10 (10.7.2 (3454)
osbock
Re: SOLVED: Spacemouse not working (MacOSX)
Post by osbock »
It's working well with the .20 beta, but I decided to try it with the .19.3 stable release, and it didn't work. The log says:
Log: 3Dconnexion driver initialized. Client ID: 57007
but nothing moves. The buttons do work though
Tomki
Post by Tomki »
Well, I think the issue is by far not solved. 3dConnexion released a new driver V 10.7.3 and it doesn‘t work.
I do not make the executable for freecad myself. Thus I depend on the dmg packages and I even don‘t get the older, stable versions to run anymore with the spacemouse. What to do?
Post by Kunda1 »
v0.20 is the stable release. Can you test and report back + paste your full About info this time?
Tomki
Post by Tomki »
The 3dconnexion driver V10.7.3 does not work at all, so I reverted back to V10.7.0.
In this case only the translation movements work, rotation movements doesn't do anything (although enabled in the customize menu).
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Tomki
Post by Tomki »
Working on a M1 Macbook with macOS Monterey V 12.5
I have to add that on my iMac Pro (Intel) with the same settings (MacOS and 3dconnexion V10.7.0) the spacemouse does work!
Also, the spacemouse worked well with all FreeCAD versions (including V021 daily builds) on my M1 MacMini with 3dconnexion V10.7.0 drivers.
OS: macOS 10.16
