If you mean "all variables that may be use in an expression", I know no way to do this.thomas-neemann wrote: ↑Wed May 25, 2022 7:05 am I mean e.g. a macro which shows all variables of a document or a sketch. or a python line from which i can create a macro
(SOLVED) Sketcher: system-generated constraint name only usable after renaming? e.g. in the formula editor
Re: Sketcher: system-generated contraint name only usable after renaming? e.g. in the formula editor
- thomas-neemann
- thomas-neemann
Re: (SOLVED) Sketcher: system-generated constraint name only usable after renaming? e.g. in the formula editor
For a good and maintainable model you should give a sensible name anyway, and that will sure not be Constraint number X.
https://github.com/dprojects/scanObjects?thomas-neemann wrote: ↑Wed May 25, 2022 7:05 amI mean e.g. a macro which shows all variables of a document or a sketch. or a python line from which i can create a macro
- thomas-neemann
- adrianinsaval
agreedthomas-neemann wrote: ↑Wed May 25, 2022 6:40 am thank you for your explanation. Isn't it wise to display it here from the system as well?
