(SOLVED) Sketcher: system-generated constraint name only usable after renaming? e.g. in the formula editor
- thomas-neemann
I only manage to use the system generated contraint name if I rename it to itself. am I doing something wrong?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28918 (Git) AppImage
Branch: (HEAD detached at 69a4963)
Hash: 69a4963ebfdbdda0d069347d013f28f2d6ba687a
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Last edited by thomas-neemann on Wed May 25, 2022 7:12 am, edited 2 times in total.
Re: Sketcher: system-generated contraint name only usable after renaming? e.g. in the formula editor
Sketch.Constraints[0]
- thomas-neemann
Thank you for your prompt reply. it works, but how do you get Constraints[0]
This is as any numbered element in FreeCAD (Face, Edge, Vertex, ...)thomas-neemann wrote: ↑Wed May 25, 2022 6:10 am Thank you for your prompt reply. it works, but how do you get Constraints[0]
'.ElementN' = '.Elements[N-1]'
The issue you have run into is, I suspect, common to many people.
The answer is given above.
It is also given in slightly longer form in the 'Referencing Objects' part of the Expressions wiki page (https://wiki.freecadweb.org/Expressions).
If the answer satisfies your need, great, but please do a follow up post if you want to know why the answer is correct.
Now a plea to the wiki writers:
In common with so much of the documentation, that page prioritises brevity over clarity and pedagogy. It is written from a programmer's point of view, not as a way to assist a non-technical new user. It would surely be much better to use a few more words to explain how stuff is stored internally (single variables vs. arrays) and the different ways you access them.
It is a very similar story with the 'Reference to CAD data' part of the page: 'If the property is a compound of fields, the individual fields can be accessed as object.property.field'. To a non-technical user, that is incomprehensible because they do not know the specialised meaning of each individual word. Even a 'data storage and retrieval 101' page that could be linked to would allow people to do a little background reading.
- thomas-neemann
thank you for your explanation. Isn't it wise to display it here from the system as well?
No opinion from my side on this.thomas-neemann wrote: ↑Wed May 25, 2022 6:40 am thank you for your explanation. Isn't it wise to display it here from the system as well?
- thomas-neemann
is there a way to display all the names created by the system?
Not sure to get your point completely. Do you mean on a single sketch, or across a complete document ?thomas-neemann wrote: ↑Wed May 25, 2022 6:55 am is there a way to display all the names created by the system?
In the form 'ContraintN' or 'Constraints[N]' ?
- thomas-neemann
I mean e.g. a macro which shows all variables of a document or a sketch. or a python line from which i can create a macro
