Hello All,
Is there an easy way to crate a housing/recepticle based on an existing housing/recepticle.
I have a male housing modeled, and would like to model the female recepticle to match. I will need maybe a 0.2mm gap for ease of fitment as parts will be 3d printed.
as you will see, there is a "pair" of male housings, these are locked together and i am unable to seperate because of the way the connector is designed in real life.
i understand i can just pocket from a solid block, but i am unsure of how to oversize the cut to allow for the .2mm tollarence
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Creating Terminal Housings and Recepticles?
- UPS Terminals.FCStd
- (404.85 KiB) Downloaded 16 times
- thomas-neemann
Re: Creating Terminal Housings and Recepticles?
if it is to be printed, a simple possibility could be to scale the mesh
- papyblaise
In my opinion, draw only one element, you will get the second part at the end with a Mirror
to have a gap of 0.2mm around the first, redraw the part to be copied with 0.2mm wider using the first as an external reference geometry
You could use a spreadsheet where you can enter your clearance as a value. That will help you if your first choice does not produce a satisfactory part as you change one number and the whole female model will be updated.
If you set the clearance to be zero, it produces the male print itself. If you set the clearance greater than zero, it produces an oversize thing that can be used to pocket out the female blank. You would have to be careful to add the correct multiple of clearance to any particular dimension (e.g. a rectangle would need 2 x clearance on horizontal and vertical dimensions. Some dimensions would need zero clearance added). This method also works if some parts of the female go inside the male - you subtract the necessary clearance from their dimensions.
i forgot this was an option. i believe ive sorted it, thanks all for the replies. waiting until i can get access to a 3d printer. but should all be good.papyblaise wrote: ↑Thu May 26, 2022 12:05 pm ... to have a gap of 0.2mm around the first, redraw the part to be copied with 0.2mm wider using the first as an external reference geometry
