[Solved] Issues scaling images on Ubuntu 22.04
leoheck
Post by leoheck »
I am experiencing issues to scale images when running FreeCad on Ubuntu 22.04
Do you guys have the same issue?
Any idea or workaround to solve this?
Thank you!
Edit: Jeeeeeesus! Forgort the version, by bad.
OS: Ubuntu 22.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: b02705d79f2e1adc7773f0c845e0acc5ae8fde4b
Python 3.10.4, Qt 5.15.3, Coin 4.0.0, OCC 7.5.1
Installed mods:
  * A2plus 0.4.56
  * Curves 0.4.3
  * fasteners 0.3.41
  * Assembly4 0.11.12
  * kicadStepUpMod 10.12.0
  * ExplodedAssembly
Shalmeneser
Re: Issues scaling images
Post by Shalmeneser »
Full version ? File to try ?
bambuko
Post by bambuko »
leoheck wrote: Thu May 26, 2022 8:06 pm ...Do you guys have the same issue?...
How would I know if "my issues" are "the same" as yours, if I don't what your issues are??
We need bit more clarity from you...
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
Bance
Post by Bance »
leoheck
Post by leoheck »
Ops, sorry, forgot to add the version. Here it is.
Version: 0.20.
Branch: unknown
Installed mods:
  * A2plus 0.4.56
  * Curves 0.4.3
  * fasteners 0.3.41
  * Assembly4 0.11.12
  * ExplodedAssembly
leoheck
Post by leoheck »
Here is a screenshot
And here what I have on Report View
01:41:06  Running the Python command 'Image_Scaling' failed:
  File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 68, in Activated
    cmdCreateImageScaling(name="ImageScaling", trackers=trackers)
  File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 214, in cmdCreateImageScaling
    ui.setupUi(d)
  File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 138, in setupUi
    self.tracker = trackers.lineTracker(scolor=(1,0,0))
  File "/usr/share/freecad-daily/Mod/Draft/draftguitools/gui_trackers.py", line 183, in __init__
    line.numVertices.setValue(2)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3989, in __getattr__
    field = self.getField(name)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3873, in getField
    return _coin.SoFieldContainer_getField(self, name)
<built-in function SoFieldContainer_getField> returned a result with an exception set<class 'SystemError'>
01:41:07  SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
01:41:07
The above exception was the direct cause of the following exception:
01:41:07  Traceback (most recent call last):
01:41:07    File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 187, in getmousepoint
01:41:07      event = event_cb.getEvent()
01:41:07    File "/usr/lib/python3/dist-packages/pivy/coin.py", line 42443, in getEvent
01:41:07      return _coin.SoEventCallback_getEvent(self)
01:41:07  SystemError: <built-in function SoEventCallback_getEvent> returned a result with an exception set
01:41:07  <class 'SystemError'>
01:41:07
01:41:07
01:41:17  <class 'SystemError'>
01:41:17  SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
01:41:17
01:41:17  Traceback (most recent call last):
01:41:17    File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 187, in getmousepoint
01:41:17      event = event_cb.getEvent()
01:41:17    File "/usr/lib/python3/dist-packages/pivy/coin.py", line 42443, in getEvent
01:41:17      return _coin.SoEventCallback_getEvent(self)
01:41:17  SystemError: <built-in function SoEventCallback_getEvent> returned a result with an exception set
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:17
01:41:18
01:41:18  Traceback (most recent call last):
01:41:18    File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 187, in getmousepoint
01:41:18      event = event_cb.getEvent()
01:41:18    File "/usr/lib/python3/dist-packages/pivy/coin.py", line 42443, in getEvent
01:41:18      return _coin.SoEventCallback_getEvent(self)
01:41:18  SystemError: <built-in function SoEventCallback_getEvent> returned a result with an exception set
01:41:18  <class 'SystemError'>
01:41:18  SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:18
01:41:21  <class 'SystemError'>
01:41:21  SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
01:41:21
01:41:21  Traceback (most recent call last):
01:41:21    File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 187, in getmousepoint
01:41:21      event = event_cb.getEvent()
01:41:21    File "/usr/lib/python3/dist-packages/pivy/coin.py", line 42443, in getEvent
01:41:21      return _coin.SoEventCallback_getEvent(self)
01:41:21  SystemError: <built-in function SoEventCallback_getEvent> returned a result with an exception set
01:41:21
01:41:21
01:41:21
01:41:50  <class 'SystemError'>
01:41:50  SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
01:41:50
01:41:50  Traceback (most recent call last):
01:41:50    File "/usr/share/freecad-daily/Mod/Image/ImageTools/_CommandImageScaling.py", line 187, in getmousepoint
01:41:50      event = event_cb.getEvent()
01:41:50    File "/usr/lib/python3/dist-packages/pivy/coin.py", line 42443, in getEvent
01:41:50      return _coin.SoEventCallback_getEvent(self)
01:41:50  SystemError: <built-in function SoEventCallback_getEvent> returned a result with an exception set
01:41:50
adrianinsaval
Post by adrianinsaval »
ubuntu and the ppa are broken, the version of pivy they ship is not compatible with python 3.10 which is their default python. Use some other packaging format (flatpak, snap, appimage)
leoheck
Post by leoheck »
Cool, thanks for this info.
The current version of it on Ubuntu 22.04 is python3-pivy_0.6.5-1build6. Since you said this version has issues, I've looked for a newer version.. and then I found this site:
https://repos.uclv.edu.cu/ubuntu/pool/universe/p/pivy/
It has this version in it, python3-pivy_0.6.7-0.1_amd64.deb
https://repos.uclv.edu.cu/ubuntu/pool/u ... _amd64.deb
After installing this new version, I did not have any other issues to scale images.
Thanks, adrianinsaval.
Syres
Post by Syres »
leoheck wrote: Wed Jun 01, 2022 1:12 am After installing this new version, I did not have any other issues to scale images.
Would it not be a good idea to document this in at least one of the following two places:
https://wiki.freecadweb.org/Pivy
https://wiki.freecadweb.org/Compile_on_Linux#Pivy
in order to assist others who might not find this topic in the search??
dpward
Re: [Solved] Issues scaling images on Ubuntu 22.04
Post by dpward »
Fix released for pivy package in Ubuntu 22.04 LTS (and Ubuntu 22.10).
https://bugs.launchpad.net/ubuntu/+sour ... ug/2000840
