[SOLVED] - Sketch origin won't match part origin
Lonfor
Post by Lonfor »
I am using a sketch attached to a datum plane.
The expected behavior is that the part's origin will be projected to the datum plane's normal and therefore the sketch, but instead, the sketch's origin is at an apparent capricious position.
I tried to correct the origin coordinates but they are not editable.
This behavior is the same if the file is created with v0.19; 0.20 dev; or Link Branch. Also begs the question: Bug or feature?
Attached is the file made with v0.19.
OS: KDE Flatpak runtime (KDE//usr/share/xsessions/plasma)
Version: 0.19.14555 (Git shallow)
Branch: (HEAD detached at 0.19.4)
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.9.9
Qt version: 5.15.3
OCC version: 7.5.1
metaldespl.FCStd
(15.05 KiB) Downloaded 23 times
freedman
Re: Sketch origin won't match part origin
Post by freedman »
I think Sketcher has some rules to try and place the zero point, like if it can find a circle it will sometimes put it there but normally it just gets placed. You can move the sketch with the attachment offset.
If the sketch is attached, you don't edit the Placement, you edit the AttachmentOffset. That is broken, you have to reattach it.
edwilliams16
Post by edwilliams16 »
I just reattached the sketch001 to the Datum Plane and I got an attachment to edit. Not sure I understand...
Screen Shot 2022-05-26 at 7.13.12 PM.png (48.47 KiB) Viewed 939 times
metaldespl1.FCStd
(8.31 KiB) Downloaded 16 times
freedman
Post by freedman »
Please give more info.
When an object is not attached we move it with placement. When attached, attachment properties are created and the object is moved with attachment offset, if the attachment is lost the attachment properties are removed.
Lonfor
Post by Lonfor »
chrisb wrote: Fri May 27, 2022 5:13 am AttachmentOffset
Okay. So the problem is not the sketch, but the datum plane that supports it. It has a disparate placement. See pic 1.
So I took a look at the Attachment Offset and everything looked fine. See Pic 2.
Then I deduced that if I compensate the Offset mismatch I would get the placement at the correct location. See pic 3.
However, it didn't happen and I've got mismatches even in micro millimeters. See pic 4. :shock:
Now I'm really confused.
Bance
Post by Bance »
It's caused by the DP's attachment.
Did you want it attached to Sketch?
freedman
Post by freedman »
It would be nice if we knew what you are trying to align. Typically we use sketch 0,0 as a origin to revolve or mirror and dimension from or rotate the sketch. The only reason to align datum plane 0,0 and sketch 0,0 is to make their rotation points the same, but I don't why you want that.
edwilliams16
freedman wrote: Fri May 27, 2022 5:47 am
I know that. What I didn’t understand was that in the OP’s file, it was showing as attached, but there was no attachment offset. I don’t know how he got into that state. When I reattached the same way the Offset appeared.
Lonfor
Post by Lonfor »
Bance wrote: Fri May 27, 2022 6:38 am It's caused by the DP's attachment.
Yup. But it looks like there is a faulty logic at where it is placed. It should be by default at 0,0.
freedman wrote: Fri May 27, 2022 6:42 am It would be nice if we knew what you are trying to align. Typically we use sketch 0,0 as a origin to revolve or mirror and dimension from or rotate the sketch. The only reason to align datum plane 0,0 and sketch 0,0 is to make their rotation points the same, but I don't why you want that.
I want the origin of the sketch (0,0) matching the part origin, or, its projection on the datum plane's normal. This is the standard behavior for all CAD packages with no exception that I know.
