Hello!
I have the part that squeezes vegetables through the lattice. It is necessary for this part to make a 3D model of the lattice (vegetable cutter cleaning net). How to do it in the easiest way?
How to make a 3d model of a lattice for a vegetable cutter?
- 2022-05-26 22-35-15.JPG (294.42 KiB) Viewed 905 times
- 4067cdd6d0cd5fbca4bf0ce3c288cdf1.jpeg (34.35 KiB) Viewed 905 times
- основа1.jpg (94.03 KiB) Viewed 905 times
Re: How to make a 3d model of a lattice for a vegetable cutter?
Linear Arrays to make the slots. I put the parameters in a Dynamic Data object. It's a Macro you'll need to get.
Filleting all the edges would be possible but slow.
- vegcutter.FCStd
- (324.86 KiB) Downloaded 13 times
Depending how much detail work you need around the edges this could be done in Sketcher using the sketch array tool. This would give you options to modify each block if needed.
It's more flexible to model the teeth with a pad, rather than cutting slots between them if you want to modify them. Here I've filleted the sides of the teeth and tapered them, making the tool easier to align.
- vegcutter2.FCStd
- (390.1 KiB) Downloaded 14 times
- Shalmeneser
- Capture d’écran 2022-05-28 112630.jpg (113.57 KiB) Viewed 649 times
- VegCut_SHALM.FCStd
- (142.63 KiB) Downloaded 11 times
