BUG: DXF Import (generated by deepnest)
MRx
Post by MRx »
The attached object should show up 3 parts in FreeCAD, however it only shows up one.
FreeCAD (original):
LibreCAD:
Solution:
I keep updating this thread during my investigation.
the commands after SEQEND seem to be handled wrong, if I remove 8 / 0 and only leave 0 after SEQEND the next POLYLINE will load. So the parameter "8" whatever that is seems to be the issue.
 1512 SEQEND
 1513  8
 1514 0
 1515   0
ok 8 could be an identifier for "Layer name (fixed)"
Now the DXF importer ignores 8.
It reads the following 0 and expects a command section afterwards, however the following 0 (directly after 8) doesn't match and misaligned the import stream for the state machine so everything just dies off there.
A fix would be:
                else if(!strcmp(m_str, "0"))
                        //get_line();
                        while(!((*m_ifs).eof())) {
                                if (m_str[0]>='0' && m_str[0]<='9')
                                        get_line();
                                else
                                        break;
it will still jump into it when it gets the unknown identifier but it will strictly expect an "entity type".
FreeCAD-git/src/Mod/Import/App/dxf.cpp
Pull Request:
https://github.com/FreeCAD/FreeCAD/pull/6924
there are so many other values not handled, it's better to try to re-align for now.
Text string indicating the entity type (fixed)
http://docs.autodesk.com/ACD/2011/ENU/f ... 9-7a62.htm
Fixed:
===== Could not solve system ======
CDxfRead::ReadLayer() - no layer name
CDxfRead::DoRead() Failed to read layer
This function will be deprecated. Please use 'convert_draft_texts'.
Convert Draft texts
Convert Draft texts
Convert Draft texts
Convert Draft texts
dxfbug.dxf
(49.16 KiB) Downloaded 97 times
OS: macOS 10.15
Version: 0.20.26556 (Git)
Branch: adaptive_dicretize_bugfix
Hash: 4357816c94ff4938b778eb9f8aba8fe0e1c917dc
Python version: 3.9.0
Qt version: 5.15.2
Coin version: 4.0.0
OCC version: 7.5.0
heda
Re: BUG: DXF Import (generated by deepnest)
Post by heda »
kudos for finding out where it stalled and doing something about it - thumbs up.
btw, the import appears to work as is with the legacy importer
Post by Kunda1 »
Indeed I echo @heda's sentiments. Thanks for the sleuthing and PR!
