objects in macro
objects in macro
hi, next one question. working with macro and i need to know where is object is not under any 'parent' object.
For example i have Body1 from Sketch1 in top of list in Model under file name, and i have body2 from sketch2 placed in Group2.
i can get Group2 by getiing body2.InList and searching for temp in body2.inList: if (temp.TypeId == 'App::DocumentObjectGroup') | (temp.TypeId == 'App::DocumentObjectGroupPython'):
but how can i get to know that object have no any above but only file_name? For example for temp in Body1.inList: will return some object (in my case i have linked one and getting it with this)
PS in short: i need to go from selected object to top of tree in Model
Re: objects in macro
You are much more likely to get help if you posted an example file and referenced the actual object names in it while re-phrasing your question.
im working on this macro and need to create Group under nearest one (where object selected or in group if group selected)
in attached file i can create any folders if group exists, but i have object "wtf" and link "wtf" - when i running script i can't know that "wtf" is top object, but i getting 'wtf001" as object above (wtf.inList returns wtf001 object)
import FreeCAD as App
import math
# Functions for getting Group
def get_parent_object(object):
list = object.InList
# #below replace
found = False
print("test---edit this to prevent going in infinity loop. need to go to top level only")
for tmp in list:
print(tmp.Module)
print(tmp.Label)
print(tmp.TypeId)
print(tmp.Parents)
#length = len(tmp)
#rightside = tmp[(length - 7):(length -1)]
#print(rightside)
return False
# #above replace as below
# if len(list) == 1:
# return list
# return False
def get_parent_group(object):
print(list)
for tmp_obj in list:
if (tmp_obj.TypeId == 'App::DocumentObjectGroup') | (tmp_obj.TypeId == 'App::DocumentObjectGroupPython'):
print(tmp_obj)
return tmp_obj
return False
def find_parent_group(object):
result = get_parent_group(object)
if result == False:
result = get_parent_object(object)
if result ==False:
return False
result = find_parent_group(object)
return result
# Function creates main Group for roof
def create_group(object, name = ""):
label = "_Ext"
numeric=0
groups = object.Group
numgroups = len(groups)
for numobjs in range(0, numgroups):
tmpobj = object.Group[numobjs]
if (tmpobj.TypeId == 'App::DocumentObjectGroup') | (tmpobj.TypeId == 'App::DocumentObjectGroupPython'):
leftside=tmpobj.Label[0:4]
if leftside == label:
length = len(tmpobj.Label)
rightside = tmpobj.Label[4:length]
if rightside == '':
rightside = '0'
int(rightside)
numeric = max(numeric, int(rightside))
numeric = numeric + 1
label=label+str(numeric)
print("-")
# Now 'label' = first free name started with _Ext and numeric suffix
# Creating Group with new name 'label'
#selFolder.Label
# selFolder.Group - contains all objects in group
# Creating new Group
doc = App.ActiveDocument
newGroup = doc.addObject("App::DocumentObjectGroupPython", label)
object.addObject(newGroup)
print(newGroup)
return newGroup
# Prepare workspace
doc = App.activeDocument()
GroupFound = False
# check selection
selected = Gui.Selection.getSelection()
selectedCount = len(selected)
if selectedCount > 0:
object = selected[0]
if (object.TypeId != 'App::DocumentObjectGroup') & (object.TypeId != 'App::DocumentObjectGroupPython'):
# First selected is other object type
if result == False:
print ("False")
else:
print(result.Label)
GroupFound = True
object = result
else:
GroupFound = True
if GroupFound == True:
print(object.Label)
ng=create_group(object)
print(ng.Label)
else:
print("group not found")
- test.FCStd
- (41.11 KiB) Downloaded 8 times
tested a little bit and i think this is like a bug
when link to object created then object added as subobject of link (totaly it is so becouse linked object made from original one). but how in this case i can determine that original object placed in top of tree?
Moved from Help forum.
I suspect that when you copy the list it is duplicated so as in FC a duplicate name will become Name001 as there could not be two identical names.
probably iterating using the obj.InList should not produce the list duplication.
InList and OutList are somewhat delicate to manipulate but being on mobile I have not access to my notes (supposed that I'm be able to find them and they are relevant )
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
first, thanks for moving im new in this forum, will try to be more attentiveonekk wrote: ↑Mon May 30, 2022 3:26 pm I suspect that when you copy the list it is duplicated so as in FC a duplicate name will become Name001 as there could not be two identical names.
Regards
Carlo D.
i'm wrote above not about copy, but about linking.
problem is when i created object in top of Model tree.
reproduce:
create any object in top of tree
running object.InList and got [[]]
creating link to object (linkobject)
running object.InList and got [[<App::Link object>]]
is there any function or property that i can get to know?
from wiki:
"Note that InList and OutList have nothing to do with the tree view of the document model that is presented in the GUI. At any time, a parent in that tree view may contain children that are part of the InList, the OutList, or neither."
if you really want to go from graphical selection in the treeview, afaik you will have to do that in the qt-treeview, search the forum for pyside treeview and you should be able to find out how to get hold of it. in order to traverse that one you will probably have to study pyside docs to figure things out..., the good news is that it knows what is graphically selected in it and it is obviously aware of what and how things are rendered there...
"in short: i need to go from selected object to top of tree in Model"
so far so good, now the bummer is that this is the result regardless if you in the treeview select the wire in wtf001 (the "linked" one) or the wire in wtf (the "original"). the whole point of link is not to recreate the object, so it is what it is...
"but how in this case i can determine that original object placed in top of tree?"
lets see what it reports as in and out...
in other words, you can't in a general case, you could in this particular case just filter out "links" from InList, like...
>>> obj = App.ActiveDocument.Wire
>>> for o in obj.InListRecursive:
... print(o.Label, o.InList)
Wire (mirrored) [<Part object>]
wtf [<App::Link object>]
wtf001 [<group object>]
links []
... print('###', o.Label)
... print('in', [q.Label for q in o.InList])
... print('out', [q.Label for q in o.OutList])
### Wire (mirrored)
in ['wtf']
out ['Wire']
### wtf
in ['wtf001']
out ['Origin', 'Wire (mirrored)']
### wtf001
in ['links']
out ['wtf']
### links
in []
out ['wtf001', '_Ext1']
[o for o in obj.InList if not 'App::Link' in o.TypeId]
Hello could you kindly put the links to the page from which you extracted this text?
I'm interested too in this sort if things so it may be a good thingbto note down the page.
TIA and Regards
Carlo D.
