Issue with Gear WB ?
cadcam
Post by cadcam »
I have a couple of oddities that I think that didn't happen
in the past, but may have mis-rembered so i am wondering if I have
subtley changed my setup
Basically I want to take a bevel gear change it's height and add a boss and a hole
Now upgraded to 0.20 - See below
1) When I select a bevel gear I thought it used to automatically attach. (seems o on an old ver 19 I have) Now
it seems to appear with the with the purple chain link, is that to be expected?
This results in an error like
error mesage
error mesage
when trying to pocket a hole.
2) The default gear has a height of 5mm and the teeth look straight
5mm
5mm
However just increasing the height only (to 12mm), not the beta, the teeth seem to gain a spiral.
Is this correct?
12mm high
12mm high
12 iso
12 iso
Many thanks for insight
OS: Windows 10 (10.0)
Version: 0.20.28929 (Git)
Hash: 9251480ddb
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * Assembly4
  * Cadcam
  * CurvedShapes 1.0.1
  * Curves 0.3.0
  * fasteners 0.3.40
  * fcgear 1.0.0
  * GDT
  * ModernUI
  * OpticsWorkbench
  * sheetmetal 0.2.49
  * ShortCuts
  * symbols_library
Re: Issue with Gear WB ?
Post by Kunda1 »
Heads up @looo
looo
Post by looo »
1. I always used gears with the part-workbench only. Not sure what have changed in freecad so the attachment is not working correctly anymore.
2. You have to take care that the height is not more than the max height. If you want a certain height of the gear you should also increase the module.
domad
Post by domad »
cadcam wrote: Sun May 29, 2022 11:42 am .......
Hi cadcam, greetings to the community!
With the default data (module = 1, number of teeth = 15, pitch angle 45 °) you can have a theoretical maximum height of 7.5 mm.
To have a height of about 12 mm while maintaining the module = 1 and the number of teeth = 15, the pitch angle should be about = 32 °.
