Aligning Origins
Aligning Origins
In order to be able to join them into one object I’m trying to place the Mount Cone Assemblies (please see the attached FreeCAD file) on the Window Bracket with numerical precision but when I set the Z origin at zero for all three objects the Window Bracket appears in a different location in the 3D window. I don’t know if it’s my lack of familiarity with FreeCAD being a newcomer to the program or if there is a glitch of some sort with my file.
How can it be explained that the Window Bracket shows up at different Z location in the 3D window when the Z value is set the same as the other two objects and is there a way to reconcile the origins so that things align?
Thanks.
Thanks.
- thomas-neemann
Re: Aligning Origins
Thanks so much for that! It's not what I'm trying to do, however. The screenshot attached to this post shows basically what I am trying to accomplish. I have been able to successfully position the Cones along the X (left and right) axis numerically, but not vertically. It seems just the Z axis of the Window Bracket is out of whack with the Z axis for the Cones. When I set Z to zero for the cones they appear where they do in the screenshot of my OP. Same for the Window Bracket. Why is the Window Bracket so far below the Cones when set to the same Z coordinate?thomas-neemann wrote: ↑Fri Jun 17, 2022 7:53 pmIf I understood you correctly, I would do it like this
https://www.youtube.com/watch?v=1CNucATmZoQ
- thomas-neemann
I find the numerical positioning more difficult than the direct / intuitive transformation and move. I've never worked my way into it and can't answer your question. unfortunately
- Shalmeneser
* Your placements are weird.
You should work INSIDE a body using the origin for easy work THEN place the entire body at its placement (using Std_TransformManip or any assembly wb).
* The 2 cone bodies are the same : use a PartDesign_Clone to express clearly this idea
* Sketch of the revolution should contain also the cylinder part. The support should only be a 3D rectangle.
* Last body :
** 1st sketch is too complex : just draw the outer rectangle.
** sketch/pocket one hole and a PartDesign_Mirrored for the other one.
** one washer then a mirror.
* Last body :
- Shalmeneser
(It should be possible to mirror the cone with Part wb or Draft wb)
- Alignment Question_SHALM.FCStd
- (74.08 KiB) Downloaded 6 times
- Capture du 2022-06-18 13-17-48.png (39.17 KiB) Viewed 1165 times
Shalmeneser wrote: ↑Sat Jun 18, 2022 9:58 am * Your placements are weird.
* Last body :
Hey! Who’s placements are you calling weird? Just kidding LOL. My placements have been called worse! Hahah. To be clear, I found that remark both helpful and a little bit amusing and I very much appreciate it and the effort you’ve made on my behalf to help me along my way. That’s just awesome of you! (Of everybody else too!)
I’ve been learning FreeCAD for about 5 weeks now. I’ve learned so much but it’s clear to me it’s just a drop in the bucket compared to what there is still left for me to learn.
Your comment about working inside a Body, then locating the entire Body later, represents a methodological approach which, while it makes entire sense to me, is a concept about which I’m uncertain I was as keenly aware previously. I’ve often thought, gee, it would be nice if there was a class I could take with a well organized and presented syllabus that teaches the concepts as well as the tools and techniques of working with FreeCAD. That sort of well rounded, structured and cohesive learning environment seems, unfortunately, absent, however, so it’s learn a bit here and there and try to piece it all together.
I’ve looked at the way you’ve structured the Cones in your reworking of my design. For me, at my level, while I can see what you’ve done, it is a bit more complicated than I think I could well manage. I did not mention previously that the Cones have to mate with another part and that for simplicity’s sake I did not include that other part in the FreeCAD file I uploaded with my OP. While I’m sure it’s doable with your construction method, just doing things at the most simple levels is often quite a struggle for me at this juncture—concepts, tools, 3D space, planes, constraints, workbenches, etc…it’s all more than a little overwhelming at times.
You have given me new tools to learn about. I could not immediately make sense of the information at the link to Std_TransformManip you provided. In looking at the info at the page PartDesign_Clone you referenced, I tried to follow the instructions there but nothing happens when I click the Create a Clone icon in the toolbar. I’ll figure it out, I’m sure, as I recall experimenting with cloning when watching some YouTube videos before. This takes me back to my comments about learning environments (above). Similarly, I have done a little Mirroring previously, but like Cloning it’s but a fuzzy memory in a torrent of new concepts, tools and methods. I’ll get there with a little more time.
More to learn! Yay!
Thanks again.
Why? What purpose is served by extending the cone below where its maximum diameter is reached? Is that so it can be coincident with the XY Plane so as to have its bottom coincident with that of the sketch of the rectangular support which is also on the XY plane? Is the lesson for me here that it can be easier to align parts for joining/fusing if they are anchored to the same plane thereby eliminating an alignment task? Something like that?Shalmeneser wrote: ↑Sat Jun 18, 2022 9:58 am * Sketch of the revolution should contain also the cylinder part. The support should only be a 3D rectangle.
And what difference does it make if the support is rectangular as you suggest as opposed to the keyhole shape I gave it?
Thanks again!
RussG Sketches: Shalmeneser Sketches:
