[SOLVED:] Sketches get moved to another plane
bambuko
Re: Sketches get moved to another plane
Post by bambuko »
fr33cadtom wrote: Tue Jun 21, 2022 10:43 pm ...I was able to support it on XY_Plane001. If I wanted to support it on the face of the gear, how would I do that?
Don't support it on the face of the gear.
You can get it to the same place as the face of the gear by editing the attachment as explained in my first reply to you:
Screenshot from 2022-06-22 06.31.38.png (47.28 KiB) Viewed 1338 times
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
drmacro
Post by drmacro »
bambuko wrote: Wed Jun 22, 2022 5:29 am
drmacro wrote: Tue Jun 21, 2022 2:15 pm .. then set the tip to the highest non-error feature and work my way down.
That's a good tip :lol: (pardon the feeble pun)
I didn't think about it - probably because I practically never experience TPN (it's so easy to avoid it ;) )
so have little practice in recovering from the mess created by it...
Umm... maybe me being pedantic...but, it is Topological Naming Problem (TNP) not Topological Problem Naming (TPN).
bambuko
Post by bambuko »
drmacro wrote: Wed Jun 22, 2022 9:47 am ...me being pedantic...
Yes, and yes - you are right :P
drmacro
Post by drmacro »
bambuko wrote: Wed Jun 22, 2022 9:57 am
TBH, I wrote that so future readers won't be scratching their heads wondering if TPN and TNP are different things. Or just a typo.
bambuko
Post by bambuko »
drmacro wrote: Wed Jun 22, 2022 10:11 am ... Or just a typo.
edited the original post to correct.
domad
Post by domad »
fr33cadtom wrote: Mon Jun 20, 2022 9:45 pm .........
Hello fr33cadtom, greetings to the community!
You just have to stick the "outerringsketch" sketch to the bottom of the face or move it to "Z" -4, and everything works again.
The reasons are easy to understand (discontinuity of faces even with the attachment of the teeth).
The "Pocket" of the "crosssketch" schetch must also be increased (up to 2 mm) to allow you to create the fillets with the face.
Fillets (all of them) it is better to create them last.
Attached pictures show:
- the flow with the fittings created last;
- the parameters of displacement of "outerringsketch" on the bottom.
Attached is the file without the fittings (the complete one would have been impossible to attach it because over 1 MB).
Ellen lamp gear-lg_2.FCStd
(326.99 KiB) Downloaded 15 times
Ellen lamp gear-lg-2_1.png (207.93 KiB) Viewed 1241 times
Ellen lamp gear-lg-2_2.png (340.43 KiB) Viewed 1241 times
fr33cadtom
Post by fr33cadtom »
Sorry I just saw the other posts on this, thanks.
Tom
fr33cadtom
All,
Thank you very much for your support. One last question. Is it better to use the origin planes and offset your sketches from there or use a Datum Plan and sketch on there? (Part 2, can you use a spreadheet value as the offset?)
Thanks again,
Tom
Shalmeneser
Post by Shalmeneser »
* Choose a solid support : plane or DatumPlane
* This DatumPlane need to have a solid support.
* DatumPlane is useful when you have to refer to this plane many times.
* DatumPlane is more visible but a sketch has the same attachment.
* If you need a rotation THEN an offset, you need to rotate via a DatumPlane THEN to offset in the sketch. (because Attachment : Offset THEN rotation)
* The offset is given directly (a number) or via an expression (from any kind of dimension : sketch, spreadsheet, ...).
fr33cadtom
Thanks again. I understand and appreciate all you help.
Tom
