How to attach SubShapeBinders to a DatumPlane
I am trying to create a number of groove sections using a single sketch. I am modelling an electrical plug with a number of similar pin profiles. The location of the pins does not follow a standard array.
In the attached file, I have created the pin_1_pocket_sk, and bound it to a DatumPoint and DatumPlane with it's origin at the center of the pin location, and created a groove with the sketch and it worked well.
I then created a SubShapeBinder (pin_5_sb) from pin_1_pocket_sk and attempted to attach it to the pin_5_plane. When I do this, the SubShapeBinder becomes 'invisible' (I suspect that it is rendered in a single point in space at the origin of pin_5_plane). Reattaching the pin_5_sb to the pin_1_pocket_sk it renders correctly.
Performing a groove operation on the pin_5_sb when attached to pin_5_plane does not produce the desired output (the same profile as on pins 1-4).
I've modelled pins 1 through 4 in the attached file to demonstrate what I'm trying to do.
Edit
Turns out I was working in RealThunder's branch which allows re-attachment of the SubShapeBinders. I opened up the file in the official weekly FreeCAD branch and it looks like am not allowed to reattach a subShapeBinder to another surface. My apologies for the confusion. I'm still left with the question of how to accomplish the "multiple operations from a single sketch problem" though.
Picture of the plug. If anyone could let me know how to get the pin_5_sb to attach properly to the ping_5_plane or a more clever way of solving this problem it would be appreciated.
Thanks in advance.
Bruce
OS: Debian GNU/Linux bookworm/sid (GNOME/gnome)
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Edit
Thanks in advance.
Bruce
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
- power_plug.FCStd
- (106.49 KiB) Downloaded 39 times
Re: How to attach SubShapeBinders to a DatumPlane
Do it with a polar pattern and a mirror, it doesn't have to be all or nothing with patterns.
There are some other problems though, the first sketch makes the holes too big, so the grooves are wasted.
Hint for a groove you need a radius not a diameter.
- power_plugBance.FCStd
- (63.97 KiB) Downloaded 34 times
- Shalmeneser
- power_plug_SHALM.FCStd
- (90.4 KiB) Downloaded 37 times
- Capture d’écran 2022-06-23 011236.jpg (68.51 KiB) Viewed 1781 times
A ShapeBinder (and SubShapeBinder) has a "Support" property, as does the AttacherExtension : these 2 Support properties mean different things though, so you can't mix the 2 functions as one "Support" confuses the other "Support". The choice of the name "Support" for a ShapeBinder is unfortunate, if it were called something else then this approach would work (Target ? Base ?).bruce wrote: ↑Wed Jun 22, 2022 8:54 pm Turns out I was working in RealThunder's branch which allows re-attachment of the SubShapeBinders. I opened up the file in the official weekly FreeCAD branch and it looks like am not allowed to reattach a subShapeBinder to another surface. My apologies for the confusion.
I don't know how LinkStage3 branch manages to do it though.
I use Draft::Clone for this: you clone your sketch, the clone can be attached and used for other operations.I'm still left with the question of how to accomplish the "multiple operations from a single sketch problem" though.
You can still reattach shape binders on the latest weekly, but you have to do it by selecting it in the Combo View and then going to Part WB -> Part menu (top) -> "Attachment...". I believe this is a remedy for the breaking based on the "Support" name overlap error. I am the one who reported that bug.
OS: Windows 10 (10.0)
Version: 0.20.29192 (Git)
Hash: fb1a7af3605ed86631afabb1eb77ae305e418d98
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: English/Germany (en_DE)
Although I can change the Attachment, the associated face doesn't change.
- I started with the ShapeBinder of Face6 (last face in direction Z)
- reattached the ShapeBinder to Face2
-> The face showing in the SubShapeBinnder is still Face6.
- attachSubShapeBinder.FCStd
- (4.73 KiB) Downloaded 35 times
When I open your attachment file with the latest weekly FreeCAD version as I mentioned in my post above I get the following attachment property for the shape binder:
It looks like it is not attached to anything, after saving to disk. The binder looks to be having face2 selected as it's shape. Then I change it's attachment to be face6:
This works as intended because the shape binder is no longer attached to the origin but to the top face of the cube, lifting it in the z-direction that the face is positioned at. After saving the file that I now modified, closing the document and reopening it, I now get the following weird result:
It looks like the previous "attachment" of the shape binder has now become it's face selection, possibly related to the issue that I have previously reported. Thus the FreeCAD file has broken at the saving stage.
I tried this option and although it seemed to work the SubShapeBinder didn't match the origin of the source to the origin of the DatumPlane as shown below. Any idea how to get the origins to align?quiret wrote: ↑Thu Jun 23, 2022 10:25 am You can still reattach shape binders on the latest weekly, but you have to do it by selecting it in the Combo View and then going to Part WB -> Part menu (top) -> "Attachment...". I believe this is a remedy for the breaking based on the "Support" name overlap error. I am the one who reported that bug.
Thank you for your help
- adrianinsaval
is there a github issue for this? As Zolko said I think we should change the name of that property to Source or something similar
I defer to @chrisb as to whether a ticket should be created.adrianinsaval wrote: ↑Thu Jun 23, 2022 5:57 pm is there a github issue for this? As Zolko said I think we should change the name of that property to Source or something similar
