sheetmetal workbench and transparancy
thegavs
Post by thegavs »
Think I have found a bug in the sheet metal workbench relating to body transparency.
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
To replicate create a flat part in part design workbench and set the transparency to a high value I used 80%
unbent transparent.png (93.8 KiB) Viewed 809 times
then swap to sheet metal workbench and add a bend to a face.
bent not transpartent.png (94.83 KiB) Viewed 809 times
The transparency setting seems then to be ignored but not reset. changing the value will bring the transparency back.
bent showing data.png (116.57 KiB) Viewed 809 times
Thoughts?
Gavin
sheetmetal transparency.FCStd
(14.77 KiB) Downloaded 13 times
papyblaise
Re: sheetmetal workbench and transparancy
Post by papyblaise »
indeed, passing through sheetmetal resets the transparency and color parameters to "default", even if they remain modified in the Body
maybe this is due to the move from Partdesign workbench to Sheetmetal which is not an addon
Post by Kunda1 »
Hi @shaise any idea what is the chicken and what is the egg here? :lol:
Is this a SheetMetal or PartDesign bug?
Edit: correct mention
domad
Post by domad »
Greetings to the Community!
Sheet Metal also behaves in the same way with "Part" objects and with objects already folded or modeled with another flow, I don't know if it can be defined as a "bug", perhaps a precise choice (?) of the developer to restore the parameters default "Object Style" or have been deemed of little importance. :?:
Syres
Post by Syres »
thegavs wrote: Thu Jun 23, 2022 1:28 pm Hi,
I've only submitted a fix to retain overall shape colour and transparency. To retain individual face colours will take some further time and testing but here's the Pull Request https://github.com/shaise/FreeCAD_SheetMetal/pull/246 submitted a short time ago.
papyblaise
a priori it's only with sheetmetal, if you make an Array with DraftWb or an op with Part Wb on a PartDesign object, the color and transparency will also disappear
Syres
Post by Syres »
papyblaise wrote: Thu Aug 04, 2022 10:25 am a priori it's only with sheetmetal, if you make an Array with DraftWb or an op with Part Wb on a PartDesign object, the color and transparency will also disappear
I hope you have not ticked Link array checkbox?
