Challenges?
FBXL5
Re: Challenges?
Post by FBXL5 »
thomas-neemann wrote: Fri Jan 20, 2023 10:46 am my clientele has had good experiences with the introduction of 2d cad. with the switch to 3d, an improvement was expected again. but there was a deterioration in terms of construction times
Maybe they forgot to properly train their staff. Or 3D data was only used to derive Drawing, because they didn't invest in machinery using interfaces to 3D software.
If one is unable to use and maintain new tools properly he will always be faster with the old ones and will never find the benefits of the new ones nor figure out smarter workflows.
Your clients must be quite smart if their parts are production ready on first try. If you have to deal with adaptions and modifications on the way to the finished product a parametric approach will save time in the end. And it is more fun to set a few properties instead building most of a part from scratch.
thomas-neemann
Re: Challenges?
Post by thomas-neemann »
FBXL5 wrote: Fri Jan 20, 2023 12:45 pm ....
there are many professionals, including an engineering office with many different systems and areas of responsibility. it can of course partly be as you suspect, but not 100%. the statement that it now takes at least twice as long but is 100%
jfc4120
Re: Challenges?
Post by jfc4120 »
A challenge on finding the amount of rotation one bend is from another:
Image and drawing file attached. I have a tube bending program I wrote in the later 1980's in BASIC, I converted to python, so the solution is fairly easy.
However I wanted to solve without the program, I came up with the same solution. Just like to see how some of you would solve it in freecad. The program gives:
D = DISTANCE BETWEEN BENDS
A = ANGLE OF BEND
R = +- ROTATION FROM PREVIOUS BEND
DW = READING ON 360 DEGREE WHEEL
SB = SETBACK
LOB = LENGTH OF BEND
     NO	D	A	R	DW	SB	LOB
1	5.73	90	0	0	0.5	0.79
2	12.21	46.54	131.56	131.56	0.22	0.41
3	6	90	-142.19	349.37	0.5	0.79
4	5	0	0	0	0	0
##########  image included also in case table doesn't show correctly.
I will post my solution a little later. Also the added planes are just to help visualize.
rotation9.FCStd
(18.44 KiB) Downloaded 16 times
thomas-neemann
Re: Challenges?
jfc4120 wrote: Fri Jan 20, 2023 7:34 pm ...
is that meant?
rotation9-tn.FCStd
(21.99 KiB) Downloaded 11 times
jfc4120
Re: Challenges?
Post by jfc4120 »
No, not that angle, the one needed is 142.19 degrees. Pretend it's pipe and you are having to rotate another elbow around.
thomas-neemann
Re: Challenges?
jfc4120 wrote: Fri Jan 20, 2023 8:14 pm ...
can you draw the angle in a hand sketch?
jfc4120
Re: Challenges?
Post by jfc4120 »
I will, on mobile now give me a few minutes and I will boot up desktop.
Edit, I am back on desktop:
It's the angle between plane 2-3-4 and plane 3-4-5, see new image: And sorry, I drew in yellow lines at the wrong places.
I will redo the image when I can.
Re: Challenges?
A = ANGLE OF BEND
SB = SETBACK
     NO	D	A	R	DW	SB	LOB
4	5	0	0	0	0	0
For a Challenge you can of course provide the data you want, but wouldn't it be more realisitic to give the points 1-5 by their xyz coordinates?
jfc4120
Re: Challenges?
Post by jfc4120 »
That's why I included the drawing each of the points if you select one at a time shows the XYZ coordinates.
Give me just a little while and I will post them. Back on desktop:
X	Y	Z
-3.28859	10.00000	4.69799
0.00000	10.00000	0.00000
10.00000	10.00000	7.00000
15.03512	6.74339	7.00000
15.03512	6.74339	12.00000
points.csv included. The table didn't post just right.
points.csv
(156 Bytes) Downloaded 14 times
Re: Challenges?
Oh, sorry, I had missed the attached file.
