Challenges?
- papyblaise
Re: Challenges?
you hope that we will make you all your project for free
don't forget to make a big donation to the fc foundation
- thomas-neemann
Re: Challenges?
don't worry I've already done it . here it ispapyblaise wrote: ↑Fri Jan 27, 2023 4:44 pm you hope that we will make you all your project for free
https://www.youtube.com/watch?v=4VRjD-Iunnc
- papyblaise
Re: Challenges?
Ha ok, so here are 2 finished just before nightfall
- portique.JPG (37.38 KiB) Viewed 809 times
- thomas-neemann
Re: Challenges?
how long did it take to get here?
can you upload your file?
Re: Challenges?
here my hopper.
@thomas:-> check your parts, the compound provided seems have some troubles.
- start260123_vb.FCStd
- (77.8 KiB) Downloaded 15 times
- Capture.JPG (25.28 KiB) Viewed 758 times
- thomas-neemann
Re: Challenges?
thanks for the cooperation. How long did it take?
your construction looks like this.
I would suspect something like that in a welded construction
Re: Challenges?
this kind of part must have a minimum of welded sheet (1 or 2) it's better to bend it.
unfortunately, sheetmetal wb can't help to design that yet.
I spend about 1 hour to think about rights face to offset.
- start260123_vb2.FCStd
- (79.49 KiB) Downloaded 18 times
- thomas-neemann
Re: Challenges?
that's right.
the best method is one. sometimes a company only has the option of welding.
Re: Challenges?
using Assembly4thomas-neemann wrote: ↑Fri Jan 27, 2023 4:07 pm the fastest workflow for this assembly and construction of the connecting element is sought
Not the fastest way, but parametric.
- start2701b_vb.FCStd
- (168.36 KiB) Downloaded 10 times
- thomas-neemann
Re: Challenges?
i have assembly4
not installed. it looks like this to me.
Is it the same for you?
