yes, if the construction path is not known in advance, parametric can also be helpful
Challenges?
- thomas-neemann
Re: Challenges?
Re: Challenges?
Like it (although the notch of the seam is missing, but that is just work, you have the only "real" ball in exchange).
Cheers,
Markus
Markus
- thomas-neemann
Re: Challenges?
corner table made of metal profiles (parametric is not necessary)
edit
here is my suggestion
https://www.youtube.com/watch?v=qaPNsYOLSKs
edit
- thomas-neemann
Re: Challenges?
here is an exercise by @flowwie
you could make a competition out of this, with which cad system and which method is the fastest to create it. parametric is not required
https://www.youtube.com/watch?v=B6q5xsVmxQE
https://www.youtube.com/watch?v=TVZWXXq3zPQ
- thomas-neemann
Re: Challenges?
This doesn't seem correct :thomas-neemann wrote: ↑Mon Sep 12, 2022 10:53 am corner table made of metal profiles (parametric is not necessary)
- thomas-neemann
Re: Challenges?
it is the result of part connect. in my opinion it is sufficient to generate dimensions for the production.
- thomas-neemann
Re: Challenges?
the fastest construction of the sloping flap with a distance of 2 mm to the main body is sought
- thomas-neemann
- thomas-neemann
Re: Challenges?
tangential transitions, parametric is not important to me. the fastest solution is sought
