Challenges?
thomas-neemann
Re: Challenges?
Post by thomas-neemann »
Shalmeneser wrote: Mon Jul 18, 2022 12:24 pm:idea:
i like it. how long does it take?
Shalmeneser
Re: Challenges?
Post by Shalmeneser »
Less than 10 min.
The pocket via DatumPlane didn't want to be PolarPatterned.
thomas-neemann
Re: Challenges?
Challenge 14.08.2022
what is the fastest method (also non-parametric) to create a 3d model from this 2d-dxf file?
start14aug.dxf
(447.91 KiB) Downloaded 26 times
Willem
Re: Challenges?
Post by Willem »
This is a hell of a job to do.
I started making 3 separate Parts for Top Front and Side and moved the shapes into that Parts.
Next is moving the Parts to the right position. Now I stop to enjoy the good weather and continue later.
If someone else want to continue you can take my file
Schermafdruk van 2022-08-14 10-51-09.png (114.86 KiB) Viewed 851 times
Challenge14aug.FCStd
(700.72 KiB) Downloaded 15 times
thomas-neemann
Re: Challenges?
Willem wrote: Sun Aug 14, 2022 9:01 am This is a hell of a job to do.
thanks for the cooperation.
a lot is symmetrical. I assume it's less than 10 minutes. I'm in the process of doing it
Willem
Re: Challenges?
Post by Willem »
In my opinion the best method is to make lines in Draft for half the model using Snap.
Redraw the lines with a Wire.
The Wire can have a standard fillet.
Make a circle and sweep that over the Wire
Use a mirror to complete the frame.
Only superman can do that in 10 minutes
Schermafdruk van 2022-08-14 12-12-43.png (126.76 KiB) Viewed 805 times
thomas-neemann
Re: Challenges?
Willem wrote: Sun Aug 14, 2022 10:18 am ....
yeah, i'm doing something like that right now. I've had a few mistakes. an experienced freecad user could do it in less than 10 minutes. the video with all wrong ways cut out will probably be less than 10 minutes
that's how far i'm at now
zs.FCStd
(759.9 KiB) Downloaded 19 times
edit
here ist the result. i will make a video
1311fin.FCStd
(789.36 KiB) Downloaded 13 times
thomas-neemann
Re: Challenges?
here is my suggestion. a video of about 5 minutes. an experienced freecad user can do it in less than 10 minutes
https://www.youtube.com/watch?v=uyiWvBapevQ
phpBB [video]
papyblaise
Re: Challenges?
Post by papyblaise »
good nap
sieste.FCStd
(910.54 KiB) Downloaded 16 times
thomas-neemann
Re: Challenges?
papyblaise wrote: Sun Aug 14, 2022 12:27 pmgood nap
the workflow is suitable for something like that, how long would it take for an experienced user
