I have been working with Inventor at work for several years.
With Inventor, the color of a point that has no more degrees of freedom changes.
Can I also set this up with Freecad?
Color point without degrees of freedom
Re: Color point without degrees of freedom
What did you try? They become green in FreeCAD's Sketcher.
- adrianinsaval
when the entire sketch is fully constrained they turn green, when the vertex in question is fully constrained but not all of the sketch it turns a lighter tone of red. If this is not the case for you you are most likely using an outdated version of freecad, try using v0.20. You can customize those colors in sketcher's preferences.
- thomas-neemann
