Since your new here I don't want to confuse things but I made a sweep macro a while back, it also has a learning curve so maybe something to use in your future here.
https://forum.freecadweb.org/viewtopic. ... 20#p597263
Sweeping pipe along 3d path
- Shalmeneser
Re: Sweeping pipe along 3d path
1) Create a new body to 'construct' the path
2) Use this path via a Binder
But there is a problem between the path and the form : Pipe fail.
- Blower Motor Vent Attempt #4 _SHALM.FCStd
- (434.71 KiB) Downloaded 11 times
- Capture d’écran 2022-06-27 164644.jpg (95.05 KiB) Viewed 483 times
Hi liongate, greetings to the Community!
.... an alternative modeling flow, without using a sweep path, which includes a nested multi "Additive loft" (nested to avoid "unexpected" behaviors of the "Additive loft").
- Nested_Multi_Loft.FCStd
- (175.67 KiB) Downloaded 7 times
- Nested_Multi_Loft.png (462.14 KiB) Viewed 461 times
liongate, I didn't have time to process your file but I made a sweep/morph, identifying the Map mode and Support might help you. I have been working on adding Morph to my Sweep macro which should make this easier to do. FreeCAD calls this "section transformation", I call it morphing.
This passes BOP.
This passes BOP.
- Morph1.FCStd
- (85.79 KiB) Downloaded 6 times
- morphing.png (121.85 KiB) Viewed 445 times
I tried two more times with the mixed_curve method. I tried B-splines and elliptic arcs to define the path. Results look good - but it doesn't pass geometry check - which isn't fatal if you are done at this point. I borrowed @Shalmeneser 's spreadsheet.
FCStd too large to upload.
