Combine, Duplicate & Position
NewJoker
Re: Combine, Duplicate & Position
Post by NewJoker »
Bance wrote: Mon Jun 27, 2022 7:25 am Can you explain this a little more?
I'm just talking about the well known limitation:
limitation 2.png (62.96 KiB) Viewed 185 times
However, I should add that there's no such limitation in the Link Branch: https://github.com/realthunder/FreeCAD/releases
Bance
Post by Bance »
But is perfectly acceptable to do this so long as the result is a single solid. So for instance to model a table, with four legs, so long as I model the top first I can then model the four legs as you describe.
But I wouldn't do that it's stupid, when I can use a feature pattern.
If I want to move features in relation to each other within a body that too is possible.
NewJoker wrote: Mon Jun 27, 2022 7:22 am So you can’t make for example two or more pads from separated sketches within the same Body.
This is a generalization which needs further explanation: You cannot create a pad from a sketch, where the resulting pad would be separate from previously modeled features in the same body.
NewJoker
Post by NewJoker »
chrisb wrote: Mon Jun 27, 2022 8:11 am This is a generalization which needs further explanation: You cannot create a pad from a sketch, where the resulting pad would be separate from previously modeled features in the same body.
Right, I should have explained it further. But it's brought up so often that one begins to simplify the explanation. And someone has already mentioned the concept of a single contiguous solid which pretty much sums up the whole thing.
