Pocket not linked to circle
adrianinsaval
Re: Pocket not linked to circle
Post by adrianinsaval »
bteddy wrote: Tue Jun 28, 2022 1:06 am I was trying to create 5 pockets.
This doesn't make sense though, you only have one sketch to make a pocket so what would be the other 4 you want?
What were the other three? How did I create them?
only you can answer that, I would assume you tried to make a pocket, didn't come out as you wanted and instead of editing the previous you created a new one many times.
bteddy
Post by bteddy »
To:Shalmeneser
Thank You
To: adrianinsaval
I sketched a rectangle, padded it to thickness. Next I needed 4 holes, one in each of the corners. I sketched a circle in each corner, then created
pockets of each (4 pockets). To finish up, I sketched a rectangle on top of the base, padded it for height, then sketched another rectangle on top of that then pocketed it original base to get wall thickness and show base with holes (5th pocket).
domad
Post by domad »
bteddy wrote: Sat Jul 02, 2022 2:45 am .......
Hi bteddy, greetings to the Community!
The animated * .gif shows how to fix the (no object linked) error in your file.
error_no_object linked.gif (271.19 KiB) Viewed 239 times
adrianinsaval
If you made 4 circles in a single sketch you need only one pocket operation, don't do it 4 times
