Is this stilll correct?: Don't use special characters in your windows user name
chennes
Re: Is this stilll correct?: Don't use special characters in your windows user name
Post by chennes »
Haavard wrote: Tue Jun 28, 2022 4:20 pm Non-working username:
HåvardJakobsen
Can you tell me whether, after attempting the installation, the directory "C:\Users\HåvardJakobsen\AppData\Roaming\FreeCAD\Mod\Assembly4" exists? I'm trying to figure out whether the problem is in the unzip code or the metadata code.
Chris Hennes
Pioneer Library System
Founder
Post by wmayer »
chrisb wrote: Tue Jun 28, 2022 9:19 pm Added it to the Windows section. How about the other OSs?
This is a Windows-only problem because a UTF-8 encoded file path is not encoded as UTF-16 (wide string) when passing it to boost::file_system::path.
It can be easily tested without creating an account with special characters. Just create the directory C:\Temp\HåvardJakobsen and put a valid package.xml into it. Now run this Python code:
App.Metadata(r"C:\Temp\HåvardJakobsen\package.xml")
It will raise the error:
Base.XMLBaseException: Fatal error at file "", line 0, column 0
Message: unable to open primary document entity 'C:\Temp\HåvardJakobsen\package.xml
Haavard
Post by Haavard »
chennes wrote: Tue Jun 28, 2022 10:48 pm Can you tell me whether, after attempting the installation, the directory "C:\Users\HåvardJakobsen\AppData\Roaming\FreeCAD\Mod\Assembly4" exists? I'm trying to figure out whether the problem is in the unzip code or the metadata code.
I deleted all AppData folders and this is the result:
After opening and closing fc the default FreeCAD folder is created as expected:
After pressing install on Assy4, the Mod\Assembly4 folder is created, so the unzip parts should work correctly. I compared the sha256 of all files in this folder to the git archive, and it matches.
Founder
Post by wmayer »
git commit 22829f8a24 fixes the utf-8 / utf-16 conversion of the file path so that Metadata can load the XML file. It still needs to be tested if this also fixes all issues with the AddonManager if the user name includes special characters.
EDIT: I have added the commit to the list of backports: https://forum.freecadweb.org/viewtopic. ... 06#p602206
Founder
Post by wmayer »
I have added a unit test to check file paths (git commit 448b1ec9f38077). After fixing the actual issue with MetadataPy the unit tests pass on my local machines (Windows/Linux) but for some reason the CI tests on Gitlab fail. The error is:
  File "/builds/freecad/FreeCAD-CI/build/Mod/Test/Metadata.py", line 114, in test_file_path
    xmlfile = open(file=filename, mode="w", encoding="utf-8")
UnicodeEncodeError: 'ascii' codec can't encode character '\xe5' in position 6: ordinal not in range(128)
Neither setting the encoding to utf-8 nor using the codecs module to open the file works.
Anyone has an idea why this happens and how to fix it? I thought with Py3 all this kind of issues should have gone.
mario52
Post by mario52 »
Hi
over 127 my "cauchemar"
App.Metadata(r"C:\\Temp\\HåvardJakobsen\\package.xml")
   Message: unable to open primary document entity 'C:\\Temp\\HåvardJakobsen\\package.xml'
App.Metadata(r"C:\\Temp\\HavardJakobsen\\package.xml")
Base.XMLBaseException: package.xml format version is not supported by this version of FreeCAD
the content .xml (good or not good ? if not good give one good .xml file)
<?xml version="1.0" encoding="utf-8" standalone="no" ?>
<package format="2" xmlns="https://wiki.freecad.org/Package_Metadata">
	<name>Bad format</name>
	<description>There is no such thing as format version 2 (yet).</description>
	<version>1.0.0</version>
</package>
FC info
OS: Windows 10 (10.0)
Version: 0.21.29283 (Git)
Hash: 15e3e86c5a683f3b2e5c7b95d4b26cd719ab367a
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
mario
chennes
Post by chennes »
That XML file is one of my "bad" example files from the test suite -- you are getting the correct error for it when you use the plain ASCII username. Is that with @wmayer's latest code, or an earlier version?
Chris Hennes
mario52
Post by mario52 »
Hi
.xml same content
version FC for the 2 tests
mario
faustino
Post by faustino »
Hi
I have the same problem with my username - António- in my instalation of Assembly4 it was installed in C:\Users\António\AppData\Roaming\FreeCAD\Mod\Assembly4 it changed ó with ó.
I have another problem but don't know if they're related, when i try to do a dimensional constraint using the formula editor with <<movel1>>#<<Spreadsheet>>.grossuraazulejo it gives an error
Dimensional constraint
Failed to convert to Quantity
in property binding 'lateral_direita#Sketch001.Constraints'
OK
My FC
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Portuguese/Portugal (pt_PT)
Installed mods:
  * Assembly4 0.12.0
openBrain
Post by openBrain »
faustino wrote: Tue Jul 05, 2022 10:06 pm I have another problem but don't know if they're related, when i try to do a dimensional constraint using the formula editor with <<movel1>>#<<Spreadsheet>>.grossuraazulejo it gives an error
This is very unlikely to be related. Please open a new topic in the 'Help' subforum and attach your file there. ;)
