[Solved] - Curve length measurements ?
How does one measure the distance on a curved line/edge of an object ?
See attached image.
Any pointers will be much appreciated.
Thank you
R.
See attached image.
Thank you
R.
Re: Curve distance measurements ?
Select the arc.
type Ctrl+Shift+P
go to the python console and type: sub.Length
hit enter and see the length.
Edit: nevermind, I see you want to measure the distance between the curves...
type Ctrl+Shift+P
- papyblaise
Your 2 curves are created in sketches , measure their distances in this sketch
I do not want to measure distances between the curves.
I was just showing two curves as an example that I want to measure their distances.
Sketch does not show curved distances.
Yes it does allow for measurement of distances between the curves but that is not what I want.
R.
R.
- papyblaise
do you want it or notYes it does allow for measurement of distances between the curves but that is not what I want.
you draw a construction line (in blue) and measure it
otherwise use the Measure function
In reply to papyblaise »
Yes I do want to know how to measure the distance.
But I do not know how to or see any tools in sketch that measures curved distances.
please advise.
Thank you.
R.
please advise.
Thank you.
R.
If the center of the arcs is the same, simple r1 - r2 = distance.
Ok let me clarify my question again :
(see new image )
I DO NOT wish to measure the distance between two curves/arcs.
I wish to measure the distance of a curved edge/line.
The curve is not a circle or a geometric shape where I can measure or calculate the curved distance.
R.
(see new image )
R.
- adrianinsaval
you mean the length of the curve? select the edge in the 3d view, right click -> send to python console, then in the python console write
sub.Length
I have done the python command sub.Length, as suggested earlier by drmarco, but it just gives me the following error
NameError: name 'sub' is not defined
