Nothing shown after playing with persistent section cut
Hello
So I've played around with the new section cut feature and after trying the "Keep only cuts visible when closing" hook I don't see anything anymore. No matter which body I show/hide, nothing is shown. Reopening FreeCAD didn't help neither. Any idea what I could do? Is there a way to "reset" this?
thanks a lot
thanks a lot
Re: Nothing shown after playing with persistent section cut
@uwestoehr
- Shalmeneser
Full version / File / Picture ?
- Cut_SHALM.FCStd
- (21.37 KiB) Downloaded 2 times
- Annotation 2022-06-28 083754.jpg (23.76 KiB) Viewed 594 times
- FreeCAD 0.20_2022-06-28 10_51_08.png (150.65 KiB) Viewed 572 times
Full Version meant to follow instructions in:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
to obtain comething like this:
OS: Artix Linux (openbox)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Italian/Italy (it_IT)
Installed mods:
Regards
Carlo D.
- Various other stuffs.
- papyblaise
all bodies are invisible (why: I don't know)
I made them visible one by one: kicking the space bar
- reducteur.JPG (70.82 KiB) Viewed 546 times
So full version is:onekk wrote: ↑Tue Jun 28, 2022 9:15 am
OS: Windows 10 Version 2009
Branch: releases/FreeCAD-0-20
Locale: German/Switzerland (de_CH)
Installed mods:
* A2plus 0.4.56a
* fcgear 1.0.0
Tried dozens of times... did never work for mepapyblaise wrote: ↑Tue Jun 28, 2022 9:29 am all bodies are invisible (why: I don't know)
I finally restored the file from backup.
Well done, Thanks.
You could add the info to the first post to make it more visible, but this is a minor issue.
Regards
Carlo D.
General note: please provide a _simple_/small file to demonstrate a bug.
To your issue, in your screenshot I can see that no cut was ever made.
That you don't see anything is because you hided everything.
Take for example this state:
You won't see anything. Why? Because when you look into the Body container, all its items are hidden: Make e.g. the last item visible and you will see something.
Concerning the section cut, once you created one, you will see it in the model tree:
- adrianinsaval
And if I'm not mistake the cut is made based on what is visible so I don't thing you'll be able to make a cut until you make at least one object visible
