thanks for the cooperation, it works. could also be used for other casesTheMarkster wrote: ↑Tue Jun 28, 2022 4:41 pm One workaround is make a compound of the wire. Part menu -> Compound -> make compound. Then select the compound and extrude it.
(WORKAROUND) Question about extrude
- thomas-neemann
Re: (WORKAROUND) Question about extrude
You can also just redraw the wire with SnapEndpoint and use that - I'd suggest there is something fishy with its placement
Cheers,
Markus
Markus
- thomas-neemann
This doesn't work for me if I understand correctly.
It did for me - after first aligning the workplane.
Cheers,
Markus
Markus
- thomas-neemann
thanks, that works, there seems to be a context to where the workplane is when creating the wire
No, works nicely here.thomas-neemann wrote: ↑Tue Jun 28, 2022 7:17 am if i want to extrude this face (in part)
Can anybody confirm this?
Here is my result file, one time I directly extruded the wire in Part along the direction (1, -1, 0), and the other time I added a ShapeBinder to the wire so that I can extrude it in PartDesign. The latter has the advantage that the normal direction can be determined automatically.
- thomas-neemann
thanks for the cooperation. yes, these solutions are no problem for an advanced user. I'm in the process of producing exercises for beginners. my solution now looks like this ( from min 2:38 )
https://www.youtube.com/watch?v=KbT7yPXSBQ8
I can confirm the issue from OP here.
I can also confirm Uwe's observation that it works with a ShapeBinder.
@uwestoehr: Please add your full FreeCAD infos.
@thomas-neemann: For future posts: Please try in master before posting or post to the Link branch subforum.
OS: macOS 10.16
Version: 0.21.29321 (Git)
Hash: 8ee773362e08d703bce9cfdcefd8e4ad424a7d44
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
* FC_SU
* DynamicData 2.46.0
* FeedsAndSpeeds 0.4.0
* fcgear
* Manipulator 1.4.3
* fasteners
* sheetmetal
* ExplodedAssembly
* Curves 0.3.0
* Assembly4 0.11.12
- thomas-neemann
yes, i've been trying to do that for some time, but in the rush it can fail from time to time. but it should be right here
first post:
But your use case is nothing for beginners. my experience is that it works best by telling that one can start with a sketch, so imagine a sheet of paper and we draw on it. This is how the sketcher WB works. When the sketch is finished, we can extrude the sketch.thomas-neemann wrote: ↑Thu Jun 30, 2022 5:23 am thanks for the cooperation. yes, these solutions are no problem for an advanced user. I'm in the process of producing exercises for beginners.
Your example uses a Wire, no sketch and it is not on a "paper sheet", meaning not on the XY base plane. Sketching in inclined planes requires some FreeCAD experience. (Concept of a datum plane, concept of attachments to planes/objects etc.) You first need to introduce this and each concept requires a video to explain it and a second one that users can practice it.
my feedback to your video is therefore:
- slow down, people need time to follow you
- take time to explain WHY you do something
- focus on a single task per video. using several workbenches requires a lot of background info (concept of workbenches, introduction to every used workbench, explanations how to work across workbenches and its limitations...)
So what you do in your 5 min video requires that users worked already some hours with FreeCAD.
Side note: please encourage users to end up with technical drawings they can share with others. This will prevent some frustrations in my experience, also to my personal experience once I learned FreeCAD. Sooner or later you need to manufacture your part and then you are forced to specify tolerances. This happened for me even when I sent a STL to a 3D printing shop.
In your case you end up with a screenshot. I would omit this because this implies to beginners that this is a sufficient end of a construction.
