(WORKAROUND) Question about extrude
thomas-neemann
Post by thomas-neemann »
if i want to extrude this face (in part)
extrudieren-frage.FCStd
(4.35 KiB) Downloaded 25 times
i get this result.
Can anybody confirm this?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * InventorLoader 1.3.0
Last edited by thomas-neemann on Tue Jun 28, 2022 7:47 am, edited 1 time in total.
adrianinsaval
Re: Question about extrude
Post by adrianinsaval »
confirmed, seems like it can't properly detect the face normal
thomas-neemann
adrianinsaval wrote: Tue Jun 28, 2022 7:21 am confirmed, seems like it can't properly detect the face normal
thanks for testing
a rectangle in the same position works, seems to be on the triangle
thomas-neemann
in partdesign is apparently the same problem
extrudieren-frage-pd.FCStd
(10.22 KiB) Downloaded 8 times
edit
it works with a sketch
thomas-neemann
workaround. if you downgrade the face before extruding, it works
onekk
Re: (WORKAROUND) Question about extrude
Post by onekk »
Strangely enough, if I extract the face using "send to python console" "context menu" item having activate Part WB in 0.20.29177.
I have done it with the Wire object obtaining the shp object (among others)
I could extrude the face without errors.
face = shp.Faces[0]
solid = face.extrude(FreeCAD.Vector(0,10,0))
Part.show(solid, "Solid")
Hope it helps.
Regards
Carlo D.
- Various other stuffs.
thomas-neemann
onekk wrote: Tue Jun 28, 2022 9:00 am ...
thanks for the cooperation. This is probably a solution for many here. I'm currently producing educational videos, so I'll probably do without the fill option. then everything works.
adrianinsaval
this could be considered a bug, @uwestoehr any idea why the face normal is not correctly picked up? or is that not the problem?
mfro
Post by mfro »
Apparently, it's not caused by FreeCAD unable to extract the face normal.
If you create a DatumLine from it in PartDesign, it looks perfect, but same result when padding along it.
PartDesign padding works with a DraftToSketch.
Cheers,
Markus
TheMarkster
Post by TheMarkster »
One workaround is make a compound of the wire. Part menu -> Compound -> make compound. Then select the compound and extrude it.
