Why does Link object Scale setting -1 (Mirror) make the will turn object's color black?
xsuper9988
Re: Why does Scale setting -1 (Mirror) make the will turn object's color black?
Post by xsuper9988 »
Roy_043 wrote: Thu Jun 30, 2022 1:27 pm In your last example you are dealing with a Link array. So I would say it is still most likely Link related.
OK
Maybe "Array_Pattern" is also based on "Link Object"
I know other programming languages
But I haven't spent time on python language
I use Freecad to draw machines
My specialty is programming "automatic mechanical control"
Thank very much for your reply
xsuper9988
found another problem
Size will also be affected
After "Place Panel" press OK button the size changes back to 1.0
ScaleSize.FCStd
(4.61 KiB) Downloaded 14 times
Roy_043
Post by Roy_043 »
Yes, it is obvious that Std_Placement cannot handle Link objects. Please create an issue on GitHub.
xsuper9988
Roy_043 wrote: Sat Jul 02, 2022 4:31 pm Yes, it is obvious that Std_Placement cannot handle Link objects. Please create an issue on GitHub.
ok
Tomorrow I will do other tests and go to github to open a new one
xsuper9988
Final result after testing
I am sure there is a problem with the Scale of the Link object
Because in Draft_Clone, Draft_Mirror will not have such a problem
I have changed the post on Github
Thank you very much @Roy_043 for your help and reply
bambuko
Post by bambuko »
xsuper9988 wrote: Sun Jul 03, 2022 4:25 am ...I have changed the post on Github
1.Can you please link Github post here?
2.Have you tested it on Link branch as well?
i.e. is the issue specific to Master branch only?
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
xsuper9988
bambuko wrote: Sun Jul 03, 2022 8:24 am 1.Can you please link Github post here?
https://github.com/FreeCAD/FreeCAD/issues/7113
@realthunder
Can you please help with this issue too?
thank you very much
bambuko wrote: Sun Jul 03, 2022 8:24 am 2.Have you tested it on Link branch as well?
The result of my test
LinkBranch does not have this problem
And I found the result of my another request update
https://forum.freecadweb.org/viewtopic.php?f=23&t=69889
realthunder
Re: Why does Link object Scale setting -1 (Mirror) make the will turn object's color black?
Post by realthunder »
Try Assembly3 with my custom build of FreeCAD at here.
xsuper9988
realthunder wrote: Thu Jul 07, 2022 4:38 am PR submitted https://github.com/FreeCAD/FreeCAD/pull/7143
Thank you very much for your help and reply :D :D :D
