Why does Link object Scale setting -1 (Mirror) make the will turn object's color black?
xsuper9988
Post by xsuper9988 »
When I open the "Placement Panel" press the OK button
Then the color of the Link mirror object will turn black and the mirror will fail
My Ver.
OS: Windows 10 (10.0)
Version: 0.20.29177 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Chinese/Taiwan (zh_TW)
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * Assembly4 0.11.12
  * Curves 0.4.4
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.43
  * lattice2 1.0.0
  * parts_library
  * pcb
  * sheetmetal 0.2.49
LinkScaleColorBlack.FCStd
(21.09 KiB) Downloaded 32 times
bambuko
Re: Why does Link's Scale setting -1 (mirror) make the object's color black?
Post by bambuko »
To "mirror" using Link scale=-1
you set it here (and no, it doesn't go black):
Screenshot from 2022-06-28 17.37.59.png (89.69 KiB) Viewed 1260 times
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 0.21.29333 (Git) Snap 94
Hash: 0c797ae6a88c226d9fd87df497e40ad1d6048044
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Installed mods:
  * ToolViewReverse_ToolBar
  * sheetmetal 0.2.49
  * Manipulator 1.4.3
  * Assembly3 0.11.3
  * fasteners 0.3.40
  * ThreadProfile 1.81.0
  * fcgear 1.0.0
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
xsuper9988
bambuko wrote: Tue Jun 28, 2022 4:40 pm To "mirror" using Link scale=-1
No
I need mirrored objects on a single axis
bambuko
Post by bambuko »
xsuper9988 wrote: Tue Jun 28, 2022 11:20 pm No
Yes, you use scale=-1 , plus modify placement.
Screenshot from 2022-06-29 06.47.58.png (101.45 KiB) Viewed 1156 times
and/or adjust position as necessary (notice nothing is black :lol: ):
Screenshot from 2022-06-29 06.52.49.png (48.56 KiB) Viewed 1156 times
or... perhaps I am guessing wrong what it is that you are trying to achieve???
xsuper9988
bambuko wrote: Wed Jun 29, 2022 5:34 am or... perhaps I am guessing wrong what it is that you are trying to achieve???
First
Thank you very much for your reply
I'm trying to achieve is to mirror "an assembly group"
Originally using Draft's "mirror"
But it changes color to all white...
(LinkScaleColorBlack22.png)
After opening "Placement Panel" and pressing OK
Your method will still be black
LinkScaleColorBlack11.FCStd
(18.96 KiB) Downloaded 21 times
xsuper9988
  1. Is the "OK function of the placement panel" making the color black an issue?
  2. If I want to request an update about the "Draft mirror will not turn white" feature, where should I ask it in the forum?
bambuko
Post by bambuko »
xsuper9988 wrote: Wed Jun 29, 2022 7:43 am I'm trying to achieve is to mirror "an assembly group"...
see my questions/comments below:
Roy_043
Re: Why does Link's Scale setting -1 (Mirror) make the object's color black?
Post by Roy_043 »
xsuper9988 wrote: Tue Jun 28, 2022 3:17 pm Then the color of the Link mirror object will turn black and the mirror will fail
Confirmed, IMO this a bug.
bambuko
Post by bambuko »
What am I doing differently? :P :?
Screenshot from 2022-06-29 10.32.26.png (79.57 KiB) Viewed 1077 times
apart from (perhaps?) using different/latest version, see below:
Installed mods:
  * sheetmetal 0.2.49
  * Manipulator 1.4.3
  * Assembly3 0.11.3
  * fasteners 0.3.40
  * fcgear 1.0.0
and the result (after pressing OK), with no sign of anything black?
Screenshot from 2022-06-29 10.36.09.png (53.06 KiB) Viewed 1073 times
PS
I have also tried using Euler angle and the same OK result ...
xsuper9988
bambuko wrote: Wed Jun 29, 2022 9:35 am
I tested the latest win version (29283)
it still has problems
But don't see the version you are using (29333)
The latest in weekly-builds only (29321)
Could you please test it with (29321)?
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Version: 0.21.29283 (Git)
Hash: 15e3e86c5a683f3b2e5c7b95d4b26cd719ab367a
Installed mods:
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * Assembly4 0.11.12
  * Curves 0.4.4
  * ExplodedAssembly
  * fasteners 0.3.43
  * lattice2 1.0.0
  * parts_library
  * pcb
  * sheetmetal 0.2.49
