Constraining an elliptical arc in sketcher
CandL
Post by CandL »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * A2plus 0.4.54b
  * BIM 2021.12.0
  * FeedsAndSpeeds 0.4.0
Sketcher module.
Because the contraint window was not big enough.
Trying to understand the best way to constrain the elliptical arc. I want one quarter of the arc. So the following should be true
  • The arcs endpoints are coincident with the adjoining line end points
    The major and minor axis and the center of the ellipse should be co-linear with end points
As you can see I still have one degree of freedom.
Thanks
Carl
domad
Re: Constraining an elliptical arc in sketcher
Post by domad »
CandL wrote: Wed Jun 29, 2022 6:04 pm .......
Hello CandL, greetings to the community!
... this is what is missing
missing constraint.gif (119.44 KiB) Viewed 594 times
CandL
Post by CandL »
Thanks ... Still not sure if I am doing it right but it works.
Here are my steps. (basically breadcrumbs for the next time I need to re-learn this)
From two fully constrained lines one vertical one horizontal.
- Create the arc segment close not on the end points
- Attach one LINE endpont to the major axis via "constrain pt to an object" (closest line end point )
- Attach other LINE endpont to the minor axis via "constrain pt to an object" (closest line end point )
- Make the end pts of the arc coincident with the end points of the lines ( 2 operations)
- Make either the major or minor axis vertical or horizontal
What I like is there are no dimensions, just geometric constraints.
Thanks for the help.
Carl
domad
Post by domad »
I'm glad you said:
CandL wrote: Wed Jun 29, 2022 7:26 pm ....
it is a fundamental rule for the best creation of constraints, it is very rare to find someone who notices this at the first tests.
Very good! ;)
Shalmeneser
Post by Shalmeneser »
:idea:
Hellipse_SHALM.FCStd
(5.6 KiB) Downloaded 13 times
Capture d’écran 2022-06-29 233839.jpg (22.31 KiB) Viewed 516 times
