Cut, Copy, and Paste are grayed out
johnshearing
Post by johnshearing »
Cut, Copy, and Paste are grayed out for me. CTRL + C and CTRL + V do not work.
Box select does not work.
Can somebody think of a reason why these would be disabled?
Much thanks,
Re: Cut, Copy, and Paste are grayed out
Hi and welcome to the forum!
I guess you still have an active task. To be seen by the Pencil near the text "Tasks".
johnshearing
Thanks Chris,
Yes, If I click the close button for the task or press the escape button then the sketcher closes and I can copy an item.
But I am watching a tutorial where the instructor is copying and pasting items with the sketcher open.
So I am wondering how to clear an active task while the sketcher is open.
Any advice would be apricated.
Also, thanks for the detailed tutorial.
I am working through it now.
openBrain
Post by openBrain »
Maybe a pointer to the said tutorial would help...
onekk
Post by onekk »
And maybe some infos about FC version used and tutorial's FC version.
There are around tutorials for 0.18 or older and many things has changed in respect to actual version.
Regards
Carlo D.
- Various other stuffs.
johnshearing
openBrain wrote: Fri Jul 01, 2022 5:30 am Maybe a pointer to the said tutorial would help...
Hi OpenBrain,
This is the link to the video tutorial which requires using cut and paste
https://youtu.be/Eka_0k5l0oM?t=672
It should open at the correct place in the video.
Thanks
johnshearing
onekk wrote: Fri Jul 01, 2022 7:59 am And maybe some infos about FC version used and tutorial's FC version.
Regards
Carlo D.
Hi Carlo,
The following is the FreeCad version info.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4 0.12.0
  * Curves 0.4.4
  * Help 1.0.3
I think the video tutorial is for Version 19
Also, thank you for your tutorial. I am looking forward to going through it.
onekk
Post by onekk »
johnshearing wrote: Fri Jul 01, 2022 2:40 pm Also, thank you for your tutorial. I am looking forward to going through it.
You're welcome.
But what tutorial of mine you are referring for?
Regards
Carlo D.
johnshearing
You're welcome.
This one here
https://github.com/onekk/freecad-doc/bl ... _v0_56.pdf
Cheers
openBrain
Post by openBrain »
johnshearing wrote: Fri Jul 01, 2022 2:35 pm This is the link to the video tutorial which requires using cut and paste
Thanks
Hi, It uses integrated Sketcher Copy function. ;)
