Manipulator WB - Annotation plane
manos
Post by manos »
Hello
I am looking for info about Annotation plane used in Manipulator WB.
For example how is created or selected.
Thanks in advance.
easyw-fc
Re: Manipulator WB - Annotation plane
Post by easyw-fc »
manos wrote: Thu Jun 30, 2022 7:14 pm Hello
Thanks in advance.
Hi @manos
it seems ATM the annotation plane is broken do to some recent FC code changes... I'm going to see if I can fix it...
manos
Post by manos »
easyw-fc wrote: Fri Jul 01, 2022 10:46 am
Hi @manos
Thanks easyw-fc . Please inform.
easyw-fc
Post by easyw-fc »
manos wrote: Fri Jul 01, 2022 11:07 amPlease inform.
Hi @manos
I've pushed a fix for the Annotation Plane.
to use it in Caliper, check the Annotation plane before starting to measure and click on the dynamically added plane
EDIT:
The fix is adding an issue:
16:45:21  <Exception> Access violation
16:45:21  1e-07 Selection.cpp(150): Unhandled Base::Exception caught in selection observer:
manos
Post by manos »
easyw-fc wrote: Fri Jul 01, 2022 2:40 pm I've pushed a fix for the Annotation Plane.
Hi @easyw-fc
Thank you so much for your prompt response.
Where shall I find and how shall I use this fix ?
manos
Post by manos »
Hi @easyw-fc
Thanks again but how shall I use this fix ?
easyw-fc
Post by easyw-fc »
manos wrote: Fri Jul 01, 2022 2:47 pm Hi @easyw-fc
1) just update the Manipulator WB through FC Tools Addon manager
2) have a look at here
https://www.forum.freecadweb.org/viewto ... 73#p293173
manos
Post by manos »
@easyw-fc I updated the Manip. WB
I would like to ask if it is possible to measure the distance between two points located at different bodies which are inside the same Std Part container.
easyw-fc
Post by easyw-fc »
manos wrote: Fri Jul 01, 2022 3:45 pm @easyw-fc I updated the Manip. WB
would you mind to attach a simple example FC file?
manos
Post by manos »
easyw-fc wrote: Fri Jul 01, 2022 4:07 pm
Sorry I forgot it.
test 2022-07-01.FCStd
(22.58 KiB) Downloaded 10 times
