line shows on closed sketch and not on opened sketch
I have a little vertical line showing up when the sketch is closed but when I open it it dissapears.
when sketch is closed:
when sketch is opened:
When I opened sketch I clicked on every element in the list and that line is not there but when I close the sketch it shows up.
I have one more example on the same sketch.
closed sketch:
closed sketch:
Re: line shows on closed sketch and not on opened sketch
Hi and welcome to the forum!
Please upload your file.
Most likely, they are in other sketches, but on different planes.....
Here is the file
- al-profile.FCStd
- (11.33 KiB) Downloaded 15 times
- thomas-neemann
it seems to have to do with the contrains. if you delete it, the line disappears
- papyblaise
clear all constraints and half of the profile
reconstruct the geometric constraints, a Pad and a symmetry
- profil.FCStd
- (29.31 KiB) Downloaded 7 times
- profil.JPG (27.07 KiB) Viewed 403 times
Found it!!
Constraint79 is a horizontal constraint between the left lower circle and the line on the X-axis. Delete this and the error is gone.
Thank you! It is a good solution although Willems is more specific.papyblaise wrote: ↑Mon Jul 04, 2022 7:23 am clear all constraints and half of the profile
