Hi Everyone.
Having seen the post by maxagaz and the response by papyblaise referring to farmhouse walls, I wonder if it would be possible the build the attached structure with walled features.
The plans show the walls and buttresses as seperate parts but I lofted the walls then lofted a buttress the made an array of it, then pocketed the doors, windows and a balcony support recess then arrayed the recess, I have included the file along with a jpg.
Does anyone think it possible to do this as a walled feature all in one, or would it need to be done in seperate parts then assembled?
Comments appreciated.
Thanks
Windmill base walls
Windmill base walls
- WMB.JPG (100.31 KiB) Viewed 665 times
- Windmill base.FCStd
- (604.83 KiB) Downloaded 10 times
- Shalmeneser
Re: Windmill base walls
Are you speaking about 3D print ?
- papyblaise
yes we can, but only in Arch Wb to make the bricks
but the file is 2.4Mo
- moulin à vent.JPG (80.92 KiB) Viewed 612 times
- Shalmeneser
Oh, you want walls with bricks !
(btw, my bad file for 3D print)
- Windmill parts_SHALM.FCStd
- (74.68 KiB) Downloaded 11 times
- Capture d’écran 2022-07-01 172842.jpg (66.17 KiB) Viewed 593 times
- papyblaise
remains to be done: walls subtract Loft
buttress subtract Loft
Buttress Polar Array
- moulin à vent1.FCStd
- (777.42 KiB) Downloaded 11 times
All models looks great ! Should be cross-posted in Arch/BIM sub-forum as showcase
- papyblaise
You're talking about my bricks , so if you like them publish them , free of right
Thank you all for your suggestions.
Papyblaise, this is exactly what I have tried to achieve (not enough practise yet).
I had thought of constructing a sold wall block and removing the unwanted areas but not got there yet.
I will post the windmill when complete.
Thanks again everybody.
