It would probably work. It's rather the "just touching" which can cause problems.
[SOLVED] Why's a Cone Solid not a Solid?
Re: Why's a Cone Solid not a Solid?
Hi KDM, greetings to the Community!
.... No, the fillets of the edges of the parallelepiped do not center anything. It centers its generation that is from how it originated, in fact the parallelepiped was generated from the rectangle that originated, or rather it was drawn, starting from one vertex (not from its center), with diagonal tracing, at the other vertex.
So when I go to modify its width (shorter side) it changes not from the center but from its vertex, with the result that it is no longer centered with respect to the cone, therefore we will have the base of the cone protruding from the face of the parallelepiped ( condition of unambiguity), while on the other hand the state of abiguity remains, which will always give rise to the error.
To remedy it, the parallelepiped (the rectangle of origin) must be centered with respect to the cone so that the abiguities disappear from the two faces.
I hope to be more understanding with the animated * .gif that explains this concept step by step.
- ambiguous2.gif (829.12 KiB) Viewed 259 times
I really, REALLY appreciate you trying to explain this.
