[Arch] starting point for modeling the first floorplan
I was pointed to this forum on https://discord.com/channels/8708774110 ... 6423650334.
I‘m searching for a architectural planning software which is free or has a cheap one time payment. I’m using FreeCAD since a few weeks for 3d printing models and I was interested if the arch wb can fit my requirements.
requirements:
- walls (not only rectangular rooms, also some with angles)
- multiple layers for
- electrical wires, bus wires, ...
- lamps, outlets, distrubution cabinets, junction boxes, ...
- Furniture planning
- 3d view of the house
- electrical wires should be able to habe not only in 2D, also 3d for better planing
- would be cool to also plan the garden
Im currently looking for a starting point how this wb is working. I only found some very old videos on yt which I think are very outdated.
I would also like to add, that I don’t want to design a new house, just a new style of of the house, it’s for a old house which needs a core refurbishment. All existing walls will be leaved like that, but the electronical wires and bus wires needs to be documented very precisely.
I hope someone can steer me into the right direction.
I have one question, is it possible to have it like the part design wb where I first draw a 2d draft and then make it 3d? Would be cool if the walls could be attached to a 2d plan.
luwol03
requirements:
luwol03
Re: [Arch] starting point for modeling the first floorplan
Moved to Arch forum.
- thomas-neemann
Thank you for your quick reply, but first of all I'm searching for a starting point to model my house. One step after each other. I would be happy with either German or English resources.
- thomas-neemann
This is the classic Arch Tutorial by the Arch/BIM/Draft and FreeCAD founder Yorik, Arch_tutorial
Search YouTube, there are a number of video there, e.g. by Regis. There are a number of examples posted in the FreeCAD forum, as well as in the OSArch community.
Good luck
Good luck
Thank you for your input.
As more as I read/watch about that topic, I think freeCAD has huge limitations for arch by design.
- I cannot draw a 2d floor plan and attach walls to it
- if I place a door and remove it I have an unexplainable hole in my walls
- thomas-neemann
no, "everything" is possible. the more you work with it, the better it gets. freecad rocks
It won't really be a floor plan because it won't include (2d representations of) doors etc., walls don't have thickness (well, they could have, but I wouldn't do it that way) and so on. The idea is to create a 3D model and then 2D floor plans, if you need them, from that 3D model. The initial 2D "skeleton" is mainly just "support geometry" for the 3D model, possibly for things other than walls as well.
I hope you are using the latest version.
For what it's worth, I'm using / learning FreeCAD for a sort of similar purpose as your case. That is, I'm modeling an existing old house that will get some changes and renovations. According to your initial post you have pretty high goals and all that will be a lot of work. Of course, it depends on how detailed you want/need to be. Good luck.
Depends on what you mean by that. You can draw lines, polylines, rectangles, circles etc (draft wb elements that are included in arch wb toolbar) on a plane and later use those as "bases" for 3D walls. That's how I create all my walls. You can also create walls from 2d sketches (in sense of sketcher workbench sketches) but I don't do that.
You may need to recompute the wall ("Recompute object" in the context menu of the wall object in the model tree view). I noticed I need to do that if I use "Undo" to undo door addition. However, if I deleted the door directly instead, I didn't need to recompute the wall.
thank you for your replies, I really appreciate that volunteering work around FreeCAD.
Yes, im using the latest 0.20 (downloaded two weeks ago).
I think I put a wrong use case thought to freecad and 3D modeling a house. FreeCAD Arch is meant to create your house in 3D, not to create 2D floor plans and add walls to that 2D plan in a linked way. I will try FreeCAD for the second time with this new informations and will comment again.
