PAD creation failure
nike
Post by nike »
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
PAD operation fails. Have created 3 separate sketches, and they all bog down on the PAD function.
22:13:19 All modules with GUIs using InitGui.py are now initialized
22:13:19 Init: Initializing freecad.freecad_glider
22:13:20 Init: Initializing freecad.freecad_glider... done
22:13:20 All modules with GUIs initialized using pkgutil are now initialized
22:13:20 Init: Loading FreeCAD GUI
22:13:20 Init: Running FreeCADGuiInit.py start script... done
22:13:22 Init: Activating default workbench StartWorkbench
22:13:22 Loading GUI of Web module... done
22:13:22 Loading GUI of Start module... done
22:13:22 Loading Start module... done
22:13:22 Init: Showing main window
22:13:22 Main window restored
22:13:22 Show main window
22:13:22 Toolbars restored
22:13:22 3Dconnexion framework not found!
22:13:22 Init: Entering event loop
22:13:22 Init: Executing event loop...
22:13:22 Init: Processing command line files
22:13:49 Module: Part
22:13:49 Loading Part module... done
22:13:49 Loading Sketcher module... done
22:13:49 Loading PartDesign module... done
22:13:49 Loading GUI of Part module... done
22:13:49 Loading GUI of Sketcher module... done
22:13:49 Loading GUI of PartDesign module... done
22:13:49 Sketcher::setUpSketch()-T:0
22:13:49 Sketcher::Solve()-DogLeg-T:0
22:13:49 Sketcher::setUpSketch()-T:0.001
22:13:49 Sketcher::Solve()-DogLeg-T:0.001
22:14:00 Sketcher::setUpSketch()-T:0
22:14:00 Sketcher::Solve()-DogLeg-T:0
22:14:03 Sketcher::setUpSketch()-T:0
22:14:03 Sketcher::Solve()-DogLeg-T:0
22:14:03 Recompute failed! Please check report view.
22:14:08 Sketcher::setUpSketch()-T:0
22:14:08 Sketcher::Solve()-DogLeg-T:0
22:14:16 Sketcher::setUpSketch()-T:0
22:14:16 Sketcher::Solve()-DogLeg-T:0
22:14:16 Recompute failed! Please check report view.
22:14:16 Sketcher::setUpSketch()-T:0.002
22:14:16 Sketcher::Solve()-DogLeg-T:0.001
22:14:35 Sketcher::setUpSketch()-T:0.002
22:14:35 Sketcher::Solve()-DogLeg-T:0.001
22:14:35 Recompute failed! Please check report view.
22:14:43 Recompute failed! Please check report view.
22:14:55 Recompute failed! Please check report view.
22:15:07 Recompute failed! Please check report view.
- repeatedly ending up with an empty body copy and PAD failures with no resolution
- want to understand what went wrong
- want to understand how to correct/avoid/troubleshoot status
Other items:
- Mac shortcut keys don't work
- no apparent way to diagnose what went wrong with the PAD failure
- might be nice if there was a built in verification process that caught this error and suggested a fix
- better error messages
- can't figure out how to turn the YZ_plane002 markings off.
- GUI - context switching with every keystroke or mouse click is awful. Sometimes I want to try 4 or 5 things without having to work my way back to the starting point each time
basic iphone stand2.FCStd
(12.37 KiB) Downloaded 11 times
Screen Shot 2022-07-02 at 9.08.35 PM.jpg (151.02 KiB) Viewed 712 times
Re: PAD creation failure
Hi and welcome to the forum!
Your first sketch is empty, your second one contains only construction geometry. Use Sketcher ToggleConstructionto switch to real geometry.
papyblaise
Post by papyblaise »
delete Body: it is empty
select all Sketch002 and change with select button
bleue line.JPG (76.15 KiB) Viewed 674 times
Shalmeneser
Post by Shalmeneser »
:idea:
your dimensions are weird.
Capture d’écran 2022-07-03 110125.jpg (65.63 KiB) Viewed 650 times
basic iphone stand2_SHALM.FCStd
(14.8 KiB) Downloaded 5 times
Capture d’écran 2022-07-03 110329.jpg (37.4 KiB) Viewed 651 times
Shalmeneser
basic iphone stand _SHEETMETAL_SHALM.FCStd
(98.83 KiB) Downloaded 4 times
Capture d’écran 2022-07-03 114333.jpg (58.84 KiB) Viewed 627 times
nike
Post by nike »
Thanks for the replies. Traveling today. Will try and work through responses soon.
nike
Post by nike »
adrianinsaval
Post by adrianinsaval »
nike wrote: Sun Jul 03, 2022 2:26 am - Mac shortcut keys don't work
be more specific, what doesn't work?
There is Sketcher_ValidateSketch but I'm not sure if it would have been useful here since your sketch only had construction geometry.
select the plane and hit spacebar
It's not clear what you mean here, please elaborate
