Using Part WB I create a torus, Angle3-> 90º then advanced utilities to create shapes, Wires from edges and I select all visible edges of the part. Then I select the wire and I do an explode compound. I select one circle of the exploded wire and do a Part cross-section, the cross-section is visible in the task tab but when I click OK it is no longer visible (Yes, I activated the toggle visibility function).
Why the cross-section is not showing?
Part_CrossSections does not contain any hints and neither does:
site:forum.freecadweb.org intitle:cross-section explode
- While in the Cross-section Task tab
- crosssection1.jpeg (32.33 KiB) Viewed 1580 times
- After pressing ok
- crosssection2.jpeg (31.55 KiB) Viewed 1580 times
Thanks.
OS: Arch Linux (sway/sway)
Version: 0.19.24415 (Git)
Branch: makepkg
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.10.5
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.5.3
Github issue:
https://github.com/FreeCAD/FreeCAD/issues/7146
Non native English speaker.
