Hi community!
Just to get familiar with the loft tool I created an additive loft with a circle (XY-plane), slot (45 degree, datum-plane), rectangle (XZ-plane, 90 degree) and after that I created a subtractive loft on the same planes with smaller geometries.
While the additive loft looks ok the subtractive loft is for me not comprehensible.
With the loft tool GUI I could select the inner sketches (circle, rectangle) on the outside of the additive loft, but not the slot in the middle.
Any ideas if I made a mistake or it might be a bug?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: German/Austria (de_AT)
SOLVED: additive loft calculation differs from subtractive loft calculation
- loft001.FCStd
- (359.56 KiB) Downloaded 11 times
- Loft001.png (144.94 KiB) Viewed 381 times
Regards,
Willy
Willy
Re: additive loft calculation differs from subtractive loft calculation
Split the circles into four arcs, loft likes to have the same number of elements per profile.
- papyblaise
you must have the same number of segments in each scketches: so make the circle with 4 arcs
and they must all be in the same direction
- loft.JPG (15.44 KiB) Viewed 357 times
- loft.FCStd
- (52.16 KiB) Downloaded 5 times
Thanks for your hint
Regards,
Willy
Willy
Thanks. It works fine now.papyblaise wrote: ↑Mon Jul 04, 2022 7:42 am you must have the same number of segments in each scketches: so make the circle with 4 arcs
Regards,
Willy
Willy
