Is Bounding Box duplicated ?
As you can see at the screenshot the bounding box of the Body seems to be duplicated. Instead of one box there are two. The back box represents what ?
- Bounding_Box_1_ 2022-07-04 16-30-35.png (62.85 KiB) Viewed 469 times
- Bounding_Box_1.FCStd
- (17.11 KiB) Downloaded 10 times
Re: Is Bounding Box duplicated ?
It looks like the bounding box withut the body's displacement (to be verified!).
- adrianinsaval
gets even weirder when you move the Part container
- Captura de pantalla 2022-07-04 103403.png (18.79 KiB) Viewed 438 times
- Bounding_Box_1-aia.FCStd
- (20.95 KiB) Downloaded 4 times
Darkness at noon.! Thanks folks.
- adrianinsaval
This looks like a bug to me so perhaps it's worth putting in the tracker, not sure who would know about this type of stuff, perhaps @wmayer ?
One bounding box is that of the Pad object and the other one of the Body object. Because a Pad is handled by the Body there are besides the Visibility and Selectable no properties shown in the View tab.
Changing the Display Mode Body property of the Body from Through to Tip hides the 2nd bounding box.
I fixed this in @Mario52 's Macro https://wiki.freecadweb.org/Macro_BoundingBox_Tracing It accounts for container Placement and multiple objects inside the container. It probably doesn't handle linked objects...
Thanks @adrianisaval,wmayer, edwilliams16
