Question on Alignment.
Bance
Re: Question on Alignment.
Post by Bance »
Ok, of course it must be the body selection, otherwise one would be operating on a feature, which as found out wouldn't work.
manos
Post by manos »
Bance wrote: Mon Jul 04, 2022 8:31 pm Ok, of course it must be the body selection, otherwise one would be operating on a feature, which as found out wouldn't work.
Are they other objects -except bodies-which can be used for alignment selection ?
Bance
Post by Bance »
Yes, other solids, so part objects and probably Arch/Bim.
The wiki just states objects, I didn't try with sketches/wires etc.
manos
Post by manos »
OK thanks @Bance
manos wrote: Mon Jul 04, 2022 8:49 pm Are they other objects -except bodies-which can be used for alignment selection ?
There are two reasons (at least) why that doesn't work: The Pad has no Placement and no AttachmentOffset and thus cannot be aligned, and it would lead to a link going out of scope.
manos
Post by manos »
OK Thanks @Chrisb
mfro
Post by mfro »
Try Std_SelBoundingBox with an added LCS at each body and select the Bodies. This will show you where they really are
Bildschirmfoto von 2022-07-05 19-05-58.png (45.08 KiB) Viewed 349 times
Cheers,
Markus
manos
Post by manos »
Thanks @mfro I will try.
Bance
Post by Bance »
mfro wrote: Tue Jul 05, 2022 4:51 pm This will show you where they really are
What has that to do with the alignment tool?
mfro
Post by mfro »
Bance wrote: Tue Jul 05, 2022 6:07 pm
Not much. But it helps to know where and why Bodies are located as they are.
Cheers,
Markus
