[Solved][NotABUG]Group+Line+vertex= BOPAlgo SelfIntersect
Simbioz
Post by Simbioz »
When vertex and line are collinear and inside a group Part Check Geometry (With BOP check) returns:
check geometry
check geometry
You must select all three elements: vertex+line+group. If only vertex+line selected for check, it returns no error.
I guess this should be allowed so that's why I added the bug tag
OS: Arch Linux (sway/sway)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * fasteners 0.3.46
  * lattice2 1.0.0
  * Help 1.0.3
BopIntersect.FCStd
(4.17 KiB) Downloaded 26 times
Non native English speaker.
drmacro
Re: [¿BUG?]Group+Line+vertex= BOPAlgo SelfIntersect
Post by drmacro »
The BOP check fail doesn't necessarily mean the solid is bad.
There is a thread that explains what it actually is used for. I'm on a tablet ATM, I can try to find it later.
Short answer: not a bug...if I understand correctly.
drmacro
Post by drmacro »
To follow up on my previous post.
In this thread: https://forum.freecadweb.org/viewtopic. ... 95#p204395
BOP check is a specific analysis tool dedicated to Boolean Operations. It is not a general validity checker for CAD models. E.g., you may want to run BOP checker in cases if you see that Boolean operation fails and you do not understand why. In such situation, BOP checker may give some hints like "this shape interferes this shape" (and then the question is what are we going to do with such models...). To conclude, BOP checker is a tool to check the quality of your operands with respect to OpenCascade Booleans only. Do not use it for general validity checks, it does not work for that.
Simbioz
Post by Simbioz »
drmacro wrote: Wed Jul 06, 2022 11:36 am To follow up on my previous post.
Thanks for the clarification.
