About the "Center of Circles" feature
- xsuper9988
Most workbenches do not support the "center of circle" feature
I only found it in "TechDraw"
"Circle center" is a useful feature (at least for me personally...)
Does anyone know why it doesn't exist in most workbenches?
Thank you very much
Thank you very much
- Center Of Circle 01.png (97.72 KiB) Viewed 735 times
- Center Of Circle 02.png (103.72 KiB) Viewed 735 times
- Center Of Circle 03.png (135.08 KiB) Viewed 735 times
Re: About the "Center of Circles" feature
When do you need it, that it doesn't appear to be available? If you external reference a circular arc in Sketcher, you get the center. If you are trying to attach something to an arc, you have concentric mode, which will attach to the center.xsuper9988 wrote: ↑Wed Jul 06, 2022 11:46 pm Most workbenches do not support the "center of circle" feature
FC lacks a comprehensive global measurement tool, because of that it might be useful for centre marks in measurement. Although I would prefer to have a better measurement tool.
For the purposes of attachment, there are a number of modes available none of which require the selection of the centre.
They don't seem to be essential to me and I have used FC everyday for over 5 years. YMMV.
- xsuper9988
Do you mean that?edwilliams16 wrote: ↑Thu Jul 07, 2022 12:22 am If you are trying to attach something to an arc, you have concentric mode, which will attach to the center.
Or is there any other faster way?
Thank you very much for your reply
- Center Of Circle Measure.png (119.33 KiB) Viewed 648 times
- xsuper9988
If you want to attach a Datum Point it is called Center of Curvature But I wasn't thinking in terms of measuring 3D models, but building them.xsuper9988 wrote: ↑Thu Jul 07, 2022 3:52 amDo you mean that?edwilliams16 wrote: ↑Thu Jul 07, 2022 12:22 am If you are trying to attach something to an arc, you have concentric mode, which will attach to the center.
- xsuper9988
OKedwilliams16 wrote: ↑Thu Jul 07, 2022 4:25 am If you want to attach a Datum Point it is called Center of Curvature
You may try Caliper from Manipulator wb
- thomas-neemann
it is available in draft and arch
- xsuper9988
Surprise...
This workbench is very easy and fast
Thank you very much for your information
May I ask what is on your "toolbar"?
These icons all look interesting
Would you mind sharing information about these ICONs?
- Center Of Circle Measure01.png (89.92 KiB) Viewed 531 times
- UI.png (286.88 KiB) Viewed 531 times
