Do triangles are disguised to rectangles ?
I created a triangle -with sketcher- as you can see in first png.
What has happened?
But when I finished editing, I saw a rectangle at the 3d view. What has happened?
- Attach2 basic tut.FCStd
- (11.05 KiB) Downloaded 7 times
- thomas-neemann
Re: Do triangles are disguised to rectangles ?
here it works. which operating system do you use?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.29365 (Git) AppImage
Hash: 59b945dcc329303ad781075ecf30544aab909415
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* InventorLoader 1.3.0
* Curves 0.5.0
* BOLTSFC
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/ubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* Manipulator 1.4.9
* Help 1.0.3
I suppose it is possible the OS is an issue with a more modern build of FreeCAD. But, I'm not sure with the appmage how things might interact.
But, more general, ubuntu 18.04 is quite old, like 8 versions of of ubuntu old. (Yes, I know LTS, but...)
- thomas-neemann
Do you have the bounding box selection display setting active?
Cheers,
Markus
Markus
- thomas-neemann
good find, that's a possibility in combination with a white background color
Hi manos, greetings to the community!
The most accredited hypothesis of this behavior is to be attributed to what @mfro affirmed and highlighted with an image by @ thomas-neemann.
If it wasn't that you set "simple color" from Preferences -> Display -> Colors -> Background color and chose the "white" color, then you also set the "white" color of the lines and vertices of the Sketches , you would see the hypotenuse of the triangle and you would notice that you have set the bounding box display.
I take this opportunity to point out that the constraints created in the triangle sketch001 are to be reviewed, my suggestion:
- size constraint of one edge / side
- equality constraint on the other edge / side
- edge / side verticality constraint
- constraint of horizontality of the other edge / side
- coincidence constraint with the center of the axes
as a rule to always follow: prefer geometric constraints to dimensional ones.
@mfrro Bless you,
@Thomas-neemann,domad Thank you,
@drmacro Shame on you.
