UI messed up in latest weekly Appimage
ifohancroft
Post by ifohancroft »
As can be seen here https://youtu.be/M3rtcglKP9U the UI of the latest weekly AppImage is messed up.
OS: Manjaro Linux (MATE/mate)
Version: 0.21.29865 (Git) AppImage
Hash: fb5c731847398c5bfbc37468ba851e70860a86d5
I have removed my configs and stuff to make sure they aren't causing the problem.
Bug report: https://github.com/FreeCAD/FreeCAD-Bundle/issues/130
I like making, breaking and modding stuff, using a soldering iron, code or both. https://ifohancroft.com
Re: UI messed up in latest weekly Appimage
Post by Kunda1 »
ifohancroft
Done!
Edited the original post to add a url to the bug report.
adrianinsaval
Post by adrianinsaval »
dpi issue? I've seen this type of situation reported before on xfce and mate systems and IIRC setting the dpi correctly solved the problem, I think there was a case where it was related to a graphics driver issue too so it's hard to diagnose.
ifohancroft
adrianinsaval wrote: Tue Aug 02, 2022 4:04 am dpi issue? I've seen this type of situation reported before on xfce and mate systems and IIRC setting the dpi correctly solved the problem, I think there was a case where it was related to a graphics driver issue too so it's hard to diagnose.
No, in my case it isn't DPI (or a theme, or a graphics driver) issue. I think it has something to do with either the current Python or Qt version or some sort of relationship between the two.
ifohancroft
The bug is still present in today's AppImage as well:
Version: 0.21.29997 (Git) AppImage
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Installed mods:
  * MechanicalKeyboards
  * sheetmetal 0.2.49
  * kicadStepUpMod 10.11.9
tonyaimer
Post by tonyaimer »
For what it's worth
My Linux Mint seems to be working OK
My details
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Locale: English/South Africa (en_ZA)
Installed mods:
  * Help 1.0.3
Cant tell you what kind of graphics card I have or any other hardware details because I don't know.
Tony
ifohancroft
Long story short but I've found a workaround.
You were right. The workaround was indeed DPI related. Setting QT_FONT_DPI to 96 or QT_SCALE_FACTOR to 1 makes FreeCAD show up as expected.
I'm still hoping to be able to narrow down the possible causes and hopefully find the root issue so I won't be marking the post as solved for now.
tonyaimer wrote: Mon Aug 08, 2022 4:53 pm For what it's worth
My details
Installed mods:
  * Help 1.0.3
Tony
@tonyaimer
Thank you! Can you please check your environment variables (by executing `env` in terminal) and see if you have any QT related ones set and to what values? Perhaps QT_FONT_DPI or QT_SCALE_FACTOR or basically anything that starts with QT?
P.S. Cool! It seems we have tagging/mentions now!
adrianinsaval
I don't know if it has to be configured specifically for Qt though, IIRC there was someone that reported solving it by changing font dpi settings on xfce somewhere.
ifohancroft
adrianinsaval wrote: Thu Aug 11, 2022 9:46 pm I don't know if it has to be configured specifically for Qt though, IIRC there was someone that reported solving it by changing font dpi settings on xfce somewhere.
Yeah, sorry. I explained the short version. Basically, at least MATE has an option to automatically set QT Font DPI based on what's set in it (I am guessing XFCE does as well). It does so by setting an environment variable. However, since my monitors are actually 92DPI, MATE correctly sets the font dpi to 92, but FreeCAD wants it to be 96 for it to work for some reason. If I force the font DPI to 96 (while still having the option for MATE to sync QT's settings) and reboot, that sets it for QT as well and now it works. I tested this before but didn't know I had to reboot.
The whole issue is a deep rabbit hole though and I haven't yet found the root cause of the problem.
