Didn't work, tryed even to place files in x64 in System32 and x86 in SysWOW64.Piero69 wrote: ↑Fri Aug 05, 2022 10:08 am solution from @jimmihenry (with a modified 64bit api-ms-win-core-path-l1-1-0.dll) works ....
Here is the download link: https://github.com/nalexandru/api-ms-wi ... K/releases
Just place the 64bit "api-ms-win-core-path-l1-1-0.dll" in FreeCAD's bin folder, and you should be good, hopefully. Please try it out maybe this is the issue.
[SOLVED] Missing file in FreeCAD_weekly-builds-29923-2022-08-03-conda-Windows-x86_64-py310.7z
Re: Missing file in FreeCAD_weekly-builds-29923-2022-08-03-conda-Windows-x86_64-py310.7z
- api-ms-win-core-path-l1-1-0.dll.png (8.22 KiB) Viewed 687 times
- jimmihenry
Sorry to hear that...
maybe there is something else that is missing? I have all the Visual C- Runtimes installed, there is a package with a easy install...
Runtimes will not hurt. At least the vcredist2015_2017_2019_2022_x64.exe and vcredist2015_2017_2019_2022_x86.exe are useful.
Download is here: https://www.techpowerup.com/download/vi ... ll-in-one/
I have also the NET Framework installed... And all MS patches. Someone mentioned the Windows-7-KB2533623 patch would be needed.
Here it is: https://github.com/beny1226/Windows-7-KB2533623
Systematic sequential procedure is recommended. I hope the runtimes will do the trick.
The modified DLL's release 0.3.1
The screenshot below shows the weekly build 29936, working as usual on my Win7.
- FreeCAD weekly build 29936.PNG (120.52 KiB) Viewed 593 times
Thank you very much!jimmihenry wrote: ↑Sun Aug 07, 2022 2:43 am
The problem was api-ms-win-core-path-HACK-0.1
Once again, Thank you very much!
/With kind regards
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.29936 (Git)
Hash: 3db79c907cd7ef2f75597efdd82ae288ac23ad01
Locale: Swedish/Sweden (sv_SE)
Installed mods:
* dodo
* fasteners 0.3.50
* PieMenu
- Version 0.21.29936 (Git).png (115.63 KiB) Viewed 549 times
- jimmihenry
Re: [SOLVED] Missing file in FreeCAD_weekly-builds-29923-2022-08-03-conda-Windows-x86_64-py310.7z
Noice . Glad you made it without upgrading to Win10.
Cheers
Cheers
in addition, now the py38 bundles are back (additional to the py310 bundles).
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
