I would like to calculate the total surface area of a part.
I know I can use the survey tool.
However, this require me to select each face manually.
Is there perhaps an easy way to select all faces to get the total surface area?
In addition, I would also like to be able to exclude faces intersecting certain planes (in the attached file, basically the "external faces of the cube") in the surface calculation.
But first, I am just trying to get the total surface area.
I am also happy with any python scripting solutions, if there are any.
How can I calculate the total surface area of an object? (and optionally exclude some planes)
- woodpile_cubic_unit_cell.FCStd
- (174.03 KiB) Downloaded 28 times
- Shalmeneser
Re: How can I calculate the total surface area of an object? (and optionally exclude some planes)
Hopefully this covers what you need with the excluding of certain faces. The procedure using your file is click on Common and run the macro. The code as you see (Line Number 5) is excluding Face1 which you'd have to amend with a line for each face to be excluded. It gives you the total surface area of the object selected and with the excluded faces.
Tested using:
import Part
s = Gui.Selection.getSelectionEx()
# ******* Add the Faces to be excluded ********
excludedReferenceList = []
excludedReferenceList.append((s[0].Object.Name, 'Face1'))
referenceList = []
component = FreeCAD.ActiveDocument.getObject(s[0].Object.Name)
nFaceArea = 0
for j, g in enumerate(excludedReferenceList):
for i, f in enumerate(component.Shape.Faces):
testFace = "('"+str(s[0].Object.Name)+"', '"+"Face{}".format(i+1)+"')"
if str(g) != testFace:
nFaceName = 'Face{}'.format(i+1)
referenceList.append((s[0].Object.Name, 'Face{}'.format(i+1)))
nFaceArea =+ nFaceArea + component.Shape.Faces[i].Area
print('Total Surface Area of '+str(s[0].Object.Label)+' is '+str(component.Shape.Area)+' mm^2')
# print('Total number of faces in '+str(s[0].Object.Label)+' is '+str(i+1))
print('Total Surface Area of '+str(s[0].Object.Label)+' minus excluded faces is '+str(nFaceArea)+' mm^2')
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* A2plus 0.4.56a
* CfdOF 1.17.4
* Curves 0.5.1
* fasteners 0.3.50
* fcgear 1.0.0
* freecad.xray 2022.4.17
* Manipulator 1.4.9
* Plot 2022.4.17
* sheetmetal 0.2.55
* Silk 1.0.0
Thank you! I tried all three methods. (That FCInfo script looks really powerful!)
Now I am just trying to figure out how to automate/semi-automate face selection and combine it with @Syres script.
Hello, how can I find the path where FCInfo Macro safes the Spreadsheet in Freecad 20.1
Gruss Martin - https://myw.ch/wordpress/
